Thread: 3.4 Installed, still have KR and high boost-now what?
Results 1 to 20 of 46
  1. #1 Re: 3.4 Installed, still have KR and high boost-now what?
    Banned - Busted For Scamming
    Feb 2009
    I see 7psi MAX on my 3.4 setup. This is because it flows really good. Headers, rockers, ported m90. You really just need some flow mods.
  2. #2 Re: 3.4 Installed, still have KR and high boost-now what?
    Jan 1970
    Maquoketa, Iowa
    Could unplug the BBV and see if you are getting the same knock first, it will limit the boost to 3-5psi.
    Also, 4* isn't that bad either, how long have you been driving the car since you dropped to the 3.4 and put the pcm in? The fuel trims could be still learning themselves and you can be locking the LTFT's in rich/lean causing the car to lean out or dump fuel when in PE or throughout your upper rpm's.
  3. #3 Re: 3.4 Installed, still have KR and high boost-now what?
    Wausau, WI
    Quote Originally Posted by FoSHO99 View Post
    about 20 hrs since they were put on. about two hours drive time. So how do I drive it for now(I am assuming stay out of knock as much as possible) so that it does learn the proper trims and how long should it take to re-learn the trim's? I guess the 3800 pcm is not tuned to much to get rid of knock, or it is so individualized that I just need a custom tune, or everyone does...
  1. FWI installed!! ...still not getting full boost though...
    By 03GTPLE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2009, 04:20 PM
  2. Installed PLOG, now studders under boost. Please help!
    By nickbuol in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-18-2009, 10:07 AM
  3. New HIDs installed and High Beam/Low Beam issue CORRECTED!!! Woot!
    By GeddyLee in forum General Tech Discussion
    Last Post: 01-29-2009, 07:26 PM
  4. High Flo Cat
    By 04gpking85 in forum General Tech Discussion
    Last Post: 09-15-2008, 01:24 AM
