Thread: Guessing I have a bad alternator, flickering lights
Results 1 to 12 of 12
  1. #1 Guessing I have a bad alternator, flickering lights
    SE Level Member Buggsy's Avatar
    Eau Claire, WI
    Hi all. I've gotten a lot of good info from this forum, but I'm looking for some confirmation or opinions on this one.
    I've been noticing that my car was starting slower for a few weeks. Then about two weeks ago, just as I said to my wife "we're going to have to get a new battery soon" the "service charging system" warning showed up on the DIC. Oddly, it went away about 3 seconds after it showed up and didn't leave any stored codes. Since it was a Delco battery, I assume it was the original and bought a battery. I bought the right group size, but the negative top post was too far back. No big deal, as I just bought a side post adapter that just screws in. At the same time, I removed and cleaned the body ground. It was covered in a copper grease like anti-seize. I sanded down the body, and cleaned the connection and screw. After all that, I started the car a few times and drove it. All was well. I hooked the charger up to it to trickle charge overnight and make sure the battery was topped off.
    Now for the problem. I didn't notice this right away until it started to get darker in the morning. Right after start up, the interior and head lights have a flicker. Oddly, the dash lights look fine. It just might be too dim to see it though. The flicker isn't tied to engine RPM, and goes away within a few minutes as the engine warms up. My assumption is the alternator, but it tests fine at Advance. I double checked my body and battery ground and it looks good. I've got about 133K miles, so I wouldn't be surprised if it isn't something like the rectifier in the alternator going out. I just can't help but think I made a lot of changes all at once. I wonder if the battery is bad, or if the topping off the battery did something. The car starts nice and strong, so the new battery fixed that.
    I'd also like to add that the grounding system on this car is kind of pathetic. I found only two ground points, the body and the transmission. If it's grounded anywhere else, please let me know so I can check it.
    Related question: How long does the transmission take to re-learn? I had some slipping before I did all this, but it got way worse after the car sat a night without the battery. It's been easily a week now and it's still slipping more than before.
  2. #2 Re: Guessing I have a bad alternator, flickering lights
    Eau Claire, WI
    Saw the issue again this morning, only my DMM was dead so I couldn't test it. I wanted switch to AC volts and see if anything shows up. I have a $50 off coupon for Advance Auto, and they have a really good return policy. I think I'll just order and alternator and try it out. I hate to drop $200 on a guess, but the $50 off coupon helps. I looked in the yellow pages and every alternator rebuild shop around is long gone.
    Buy Worldwide Alternator - 125 Amps P8293 at Advance Auto Parts
  3. #3 Re: Guessing I have a bad alternator, flickering lights
    Pennsylvania
    What year vehicle? A whole slew of the 04+ have weird alternator with a clutch that causes all kinds of demons.
  4. #4 Re: Guessing I have a bad alternator, flickering lights
    Eau Claire, WI
    Title says its a 2004. The door sticker says made 09/2003. Right in the odd series II/III crossover time. I'll have to double check, as it doesn't seem visually obvious. I'll walk in to the store with it to compare before I pay.
    The timing of it is just bad. It's possible that this issue has existed for a while, but thanks to the time change I am only now *starting* the car in the dark.
  5. #5 Re: Guessing I have a bad alternator, flickering lights
    Pennsylvania
    Just might have a clutchy alt. The difference is in the pulley... should see either a plastic cap over teeth or a just a plain pulley with a hex nut.
    Wonder if Morad Parts Company - 3800 Motors, Transaxles, & Stock Parts will have a used one for you. Could also try car-part.com to find a local one. Gotta be less than $150.
  6. #6 Re: Guessing I have a bad alternator, flickering lights
    Eau Claire, WI
    I see the difference now, thanks. I'll have to double check when I leave work. I've checked a lot of places and almost all are at $199 and up. I liked autopartwarehouse.com before, but even they were expensive. The Advance coupon gets it down to $150, reman'd, and I don't have to ship a core back anywhere. Plus, I'm just testing this, so if it's not the issue, I'd have to eat a restocking fee at most places. Oh, my local junk yard has nothing, which just kills me because of how popular the 3800 is, and one that is further away doesn't have an inventory of them. They say I'm welcome to look and pull.
    I know the rebuild place the use to be here would have done it for less than $100.
    So all in all, it's the clutch part that costs so much. What does that even do for an alt? Gain back 1 HP or something?
  7. #7 Re: Guessing I have a bad alternator, flickering lights
    Pennsylvania
    Yeah, I think the point of it was to reduce parasitic drag when less power was needed, which is a sweet sentiment that should save mpg, but really only means broken alternators.
  8. #8 Re: Guessing I have a bad alternator, flickering lights
    Eau Claire, WI
    I was able to take a couple of minutes with the DMM this morning.
    Before starting the car I had 12.5 volts at the battery, and 12.45v at the alt and the fuse box.
    After starting the car (lights flickering) I had 15.9 volts at the battery, 16v at the alt, and 15.9 at the fuse box.
    With the car running, and after the flickering stopped, all voltages had dropped .5v.
    My DMM doesn't read fast enough to show me if the DC voltage was jittery. I'd like to read it on a scope to see if it's still square, but I don't have anything to do that with.
    I don't know about this car specifically, but without mods I should be putting out about 14.5 volts from the alt right? I was also able to measure around .2 volts AC on the alt. After the flickering stopped, that was around .1v.
    I did verify that I have a clutch alt as it has that plastic cap on the pulley.
    Something else I noticed is that the alt does not connect directly to the battery of the fuse box. My first thought was "how stupid to route the power trough other points before the battery and the fuse box". But then I wondered if that wouldn't actually buffer the system from erratic alt voltage.
  9. #9 Re: Guessing I have a bad alternator, flickering lights
    seems like your alt is over charging, which is just as bad as under charging. over 14. is usually not good.
    i went through 3 rebuilt alts, ( in one day) the 1st 2 were both over charging, my truck did not run right at all. 3 rd alt was a charm.
  10. #10 Re: Guessing I have a bad alternator, flickering lights
    Pennsylvania
    Hm. OH. Probably not the issue, but there's the slightest chance that some previous owner put a voltage booster on the alt. No harm in looking for it plugged into the top of the alternator.
    But while you're playing with electricity, may as well run a cable from the alternator to the fuse box as many of us have done. It definitely helps.
  11. #11 Re: Guessing I have a bad alternator, flickering lights
    Eau Claire, WI
    I did look for a voltage booster. I saw it somewhere in this forum before, but it's just a stock connector.
    I think I will run some new cable. I'll just but a roll of 4 gauge and start rewiring the main connections. I'd like to convert to side post anyways, so it's a good time to do it. I noticed the grounds were tiny too, so probably upgrade all that too.
    Thanks for the info. I ordered a new alt for pickup and we'll see if it changes anything.
  12. #12 Re: Guessing I have a bad alternator, flickering lights
    Eau Claire, WI
    I picked up a new remaned alt yesterday and dropped it in today. Started the car up without any flickering of the lights. I checked the voltage output on the alt and it was a tad high at 14.7v. After about a minute, the reading was down to 14.4v, and with some extra load on the system, it dropped to a low of 14.2v. All-in-all I'm happy. The old rule of thumb was 13.5v-14.5v, so I'll run with this. I also picked up and installed a pre-made 30 inch cable from the alt to the fuse box. No obvious gain from it, but the voltage reading was identical to the alt output instead of the previous .5v drop. I think as a winter project I'll build a new harness out of 4 or 2 gauge, and make a bunch of new grounds.
    Thanks for the help all.
  1. Dyno guessing time. Result: 266 WHP
    By matt5112 in forum Off Topic Discussion
    Last Post: 11-30-2011, 08:31 AM
  2. Guessing possibly blower motor?
    By Tommyp2010 in forum General Tech Discussion
    Last Post: 08-22-2011, 02:29 PM
  3. Test your 3800 knowledge (Guessing welcome)
    By BillBoost37 in forum Off Topic Discussion
    Last Post: 05-11-2011, 06:13 AM
  4. Flickering DIC
    By jeepers in forum Audio, Security & Visual Electronics
    Last Post: 04-02-2011, 09:24 AM
  5. HID's flickering?
    By JESSEGOTTA GP GT in forum Visual/Body Modifications
    Last Post: 02-25-2010, 01:31 PM
