Quote Originally Posted by Sabrewings View Post
It's used in a lot of the trucks at work. The dye is broken down and dissolved in the first few hundred miles. If the Air Force goes out of their way to use it at the recommendation of the analysis dept (does analysis on all engine oil, including gasoline, diesel, and jet turbine engines), then I will definitely run it in my car.
x2 thank you for this input.
