Thread: Start up problem?
Results 1 to 3 of 3
Gortox454 Start up problem? 10-07-2009, 03:53 AM
Gortox454 Re: Start up problem? 10-07-2009, 03:55 AM
BillBoost37 Re: Start up problem? 10-07-2009, 07:23 AM
  1. #1 Start up problem?
    Zeeland, Michigan
    Hey guy's, i just took my battery out because i thought i needed to remove it to replace the washer fluid pump, needless to say i didn't have too. i ended up getting to it from the passenger inner fender, but that's besides the point. i cleaned the battery up and put it back in and the new pump works fine and all. But, i go to start the car and i turn the key, i get a click like the battery is dead and all the electronics flash on then off, i try it a couple more times and it starts right up like nothing ever happened. So i move the car and think nothing of it. when i go to leave again i get the same thing, then it starts like nothing happened. is this a common electrical issue or anything? Thanks!
    -Gortox-
  2. #2 Re: Start up problem?
    Zeeland, Michigan
    oh, and it's a 2002 gtp
    -Gortox-
  3. #3 Re: Start up problem?
    Pull the cables again. There is either corrosion or a bad connection which is causing you not to get enough power to the starter to start the car. But there's plenty to run the small accessories.
  1. where to start
    By bitterpill in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-16-2009, 10:46 PM
  2. Where to start?
    By mminchau in forum General Tech Discussion
    Last Post: 05-31-2009, 10:51 AM
  3. Taking a few seconds to start? Starter the problem?
    By Z28 in forum General Tech Discussion
    Last Post: 03-27-2009, 11:09 AM
  4. '98 GTP wont start - alarm problem?
    By quadratokn in forum Audio, Security & Visual Electronics
    Last Post: 02-14-2009, 02:42 PM
