Thread: trouble with my thermostat or ECT sensor
Results 1 to 5 of 5
  1. #1 trouble with my thermostat or ECT sensor
    Oshkosh
    I have a 98 gtp that just has the service engine soon light on. I had it scanned and the print out said either the thermostat or the engine coolant temperature sensor is defective since one of them are not taking the correct temp. reading of the coolant. I noticed my temperature gauge varying back and forth while I was driving the other day. Would that push me to believe that the thermostat or ECT sensor is shot?
  2. #2 Re: trouble with my thermostat or ECT sensor
    SE Level Member shawnz90's Avatar
    Kenosha
    replace the thermostat first. It's easy to do and costs less than 10.00 if the problem is still not gone its the other.
  3. #3 Re: trouble with my thermostat or ECT sensor
    Oshkosh
    Thanks, I replaced the thermostat and still have the problem. Do you know where the ECT is? I know there is two of them but don't know which one is the main sensor and where it is.
  4. #4 Re: trouble with my thermostat or ECT sensor
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    look under the thermostat housing on the lower intake manifold. the other is just a coolant level sensor on the radiator.
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  5. #5 Re: trouble with my thermostat or ECT sensor
    I live here. UR LOSN's Avatar
    Rockford, IL
    moved to correct section
  1. Trouble History With Camshaft Position Sensor
    By SyntheticShield in forum General Tech Discussion
    Last Post: 06-04-2009, 01:21 PM
  2. Thermostat!????
    By fratzke7 in forum General Tech Discussion
    Last Post: 03-16-2009, 11:35 AM
  3. Trouble History With Crankshaft Position Sensor
    Last Post: 12-23-2008, 09:43 PM
  4. 180 thermostat
    By LMCOOK87 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-14-2008, 03:00 AM
  5. What Thermostat Should I Get ?
    By stlmo_gtp in forum Off Topic Discussion
    Last Post: 03-10-2008, 07:00 AM
