Thread: battery or alternator?
Results 1 to 6 of 6
  1. #1 battery or alternator?
    Alabama
    ok so i was out and about today and when i went back to my car it would not start. the inside lights and gauges flickerd but no start. so i jumped it off and got home. but right after i jumped it off the computer said charge system fail. but i got home. so i uncranked and recranked but some thing nothing.
    when going home the head lights flickered and when highs were put on the radio ccut out for a second. and volts were ever where from 13 to 15 the whole time. so what is it?
    1 is it the battery or
    2 the alternator or
    3 none of those or
    4 all of the above?
    thanks so much
  2. #2 Re: battery or alternator?
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    when my batt died my lights went out and the stereo died a cupple times then when i shut off the car i had no lights or anything
    if thats your problem then i'd say battery
    if you can run the car (on its own power) then its not the alt
  3. #3 Re: battery or alternator?
    Alabama
    that makes me some what happy! so when i get a new battery what kind of power should it have?
    i mean CCA and CA?
    thanks!
  4. #4 Re: battery or alternator?
    Charles City, IA
    Try charging the battery on trickle over night and see if it starts the next day.
    SMGPFC Two Nipple General
  5. #5 Re: battery or alternator?
    GT Level Member mvp2765's Avatar
    Chicago
    most likely battery.If it doesnt work after you charge it..replace it... i just bought two batteries for both of my cars with in the past month..Both batteries failed on me. I couldn't start either car and i thought both times that it was something with the engine or alternator..
  6. #6 Re: battery or alternator?
    Cedar Rapids, IA
    do what 01GTP says
    but if it doesn't start get above the stock ratings that way you have plenty of power and make sure it has a warranty
  1. Battery Dead.. Perhaps from the AMP?
    By Supercharged03GTP in forum Audio, Security & Visual Electronics
    Last Post: 10-02-2009, 11:15 AM
  2. battery help!
    By DDPeppa in forum General Tech Discussion
    Last Post: 08-23-2009, 11:49 PM
  3. battery dying
    By jaketrey32 in forum General Tech Discussion
    Last Post: 07-29-2009, 05:10 PM
  4. okay, I took the battery out of my '96 GP
    By karkev in forum General Tech Discussion
    Last Post: 06-17-2009, 09:21 PM
  5. Small battery
    By Arkanzan Wheeler in forum General Tech Discussion
    Last Post: 05-24-2008, 10:33 PM
