Thread: Do you see any problems with this build??
Results 1 to 2 of 2
Threaded View
glanzergtx Do you see any problems with... 10-01-2009, 03:56 PM
Bio248 Re: Do you see any problems... 10-01-2009, 10:13 PM
  1. #1 Do you see any problems with this build??
    GT Level Member glanzergtx's Avatar
    Dec 2008
    Sioux Falls,SD
    As most of you know my situation with my motor with the antifreeze in the cylinders. Any who. Here are the mods that im putting in my other motor to just swap in. (along with a TEP tranny)
    L67 longblock (62k on it) (bought)
    PRJ LL cam
    L36 pistons (from ed morad) (bought)....now am i going the right way for higher compression or do i want it lower??
    my p/p heads i had in the garage for over an year (bought)
    Ported LIM i have had in the garage (bought)
    Modified retainers (bought)
    comp cam pushrods (bought)
    p/p blower (bought) possibly upgrade to genV
    TOG headers (bought)
    105 springs or 90's havent decided
    Will go intercooling eventually but not right away.
    This all be ran on 65# injectors and e85 (bought)
    L36 have a 9.5:1 compression ratio vs. 8.5:1 on the L67/L32. 2004+ (L26) n/a is 9.4:1
    So with higher compression (possibly less boost) i may not make the power as i would with lower compression and more boost? BUT if i can run more boost and higher compression i would be golden in HP??
    Any thoughts or ideas on this build would be greatly appreciated.
    Thanks
    Just your normal 730whp 4dr family car.
  1. 280-340 HP build
    By patturlington in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-11-2011, 02:33 AM
  2. BLUEGTP91's BUILD...Page 25 has some vids :D
    By blueguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-19-2010, 10:32 PM
  3. Cancelling my build.
    By 69Fiat in forum Off Topic Discussion
    Last Post: 08-11-2009, 08:28 PM
  4. * VID of motor build *
    By RED GTX in forum Off Topic Discussion
    Last Post: 07-19-2008, 09:13 AM
  5. SQ Build... the begining
    By JCG's-GTP in forum Audio, Security & Visual Electronics
    Last Post: 06-28-2008, 07:28 PM
