Thread: Heads Up Display problem. Please help!
Results 1 to 5 of 5
  1. #1 Heads Up Display problem. Please help!
    Oregon
    Hay, First off, sorry if im not posting this in the correct section. Anyways, I recently acquired a 2007 base model. I've had it for about a month and a half and I love it! Anyways, I installed an after-market stereo deck today with a cheap $15 wiring harness. I am aware that It wont retain RAP, chimes, bose/monsoon, or onstar. I am ok with that. Just about everything went smoothly even turned the deck on and cranked it up and it worked the first time. It wasn't until after I had put everything together that i noticed that I had to reset the HUD. Prolly wiped the eprom chip or something when i disconnected the battery ground. I went through the process of re-entering time/date and the settings for lights delay and locks delay. Since I always set it to display the date I set it to show that. It showed the date for about three seconds then just displayed a bunch of lines, as if it reset. So I tried resetting it a couple of times and it still didn't retain the date. I tried shutting off the ignition, and turning it back on and it still did the same thing. Hopefully there is just a battery or capacitor in it that just needs to charge overnight or something, but I'm worried that I many have fried my HUD. Has anybody had this happen and know how to fix it, or are there any suggestions? I don't know how much new HUDs are but I guess I will look after this post. Thank you for taking the time to read this.
  2. #2 Re: Heads Up Display problem. Please help!
    Charles City, IA
    Your talking about the DIC in the dash. Not the Hud on the windshield. Diver Information Center. I am pretty sure.
    SMGPFC Two Nipple General
  3. #3 Re: Heads Up Display problem. Please help!
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    and if you are i'm about 90% sure it won't show the time as that was controlled by your factory radio therefor the DIC won't know the time
  4. #4 Re: Heads Up Display problem. Please help!
    Oregon
    Yeah it is the DIC, sorry 'bout that. And thank you for the help. I thought that since it retained the date for a few seconds that it was something wrong with it. Is there anything I can do other then getting the $150 harness. Its not that I really need the date on there, but it does look like crap just displaying a bunch of lines. Thanks again!
  5. #5 Re: Heads Up Display problem. Please help!
    Wausau, WI
    I believe my friend, that you are SOL...that is just the way they operate.
  1. Problems with my heads up display. 04 gtp
    By John_Shughart in forum Audio, Security & Visual Electronics
    Last Post: 07-11-2009, 02:41 AM
  2. heads up display
    By dmoney01 in forum General Tech Discussion
    Last Post: 02-16-2009, 10:36 PM
  3. heads up display
    By bb52190 in forum General Tech Discussion
    Last Post: 09-26-2008, 04:30 AM
  4. Heads Up Display
    By shamb1s in forum Audio, Security & Visual Electronics
    Last Post: 06-14-2008, 12:34 PM
