Thread: GOT MY BOOST GAUGE i have some Q's
Results 1 to 18 of 18
  1. #1 GOT MY BOOST GAUGE i have some Q's
    May 2008
    McHenry IL
    Hi guys where did everybody with a boost gauge in the a pod run the vaccum line through in the firewall?? also does anybody have a good pic of what line to tap into in the enginebay? thanks alot
  2. #2 Re: GOT MY BOOST GAUGE i have some Q's
    the vacuum line that sees boost and vacuum...
    how are you rebuilding a motor again? i dont see how its possible when you cant figure out a mechanical boost gauge.
    if you are still lost, put a T fitting on the MAP sensor nipple and run the vacuum line across with your fuel lines and into the cabin through the firewall by the drivers feet.
  3. #3 Re: GOT MY BOOST GAUGE i have some Q's
    Charles City, IA
    Go threw the gromet in the floor like stated in your other thread. T into the map sensor vacuum line.
    SMGPFC Two Nipple General
  4. #4 Re: GOT MY BOOST GAUGE i have some Q's
    May 2008
    McHenry IL
    NO NO NO bio ughhh im saying i have it all wired in and ready to go the vacum line is already connected to the back of the gauge im jsut wondering where exactly to go through the firewall at and what to T into
  5. #5 Re: GOT MY BOOST GAUGE i have some Q's
    May 2008
    McHenry IL
    thanks 01gtp but are you talking about the gromet on the passenger side? i think gtpsleeper didnt give me enough hose haha
  6. #6 Re: GOT MY BOOST GAUGE i have some Q's
    just go through the firewall down by the drivers feet. take off the panels under the dash and look where the wires go out. push it through there.
    the grommet in the floor on the passenger side is way out of your way.
  7. #7 Re: GOT MY BOOST GAUGE i have some Q's
    Charles City, IA
    Never really looked on the drivers side I will have to do that for mine.
  8. #8 Re: GOT MY BOOST GAUGE i have some Q's
    May 2008
    McHenry IL
    i cant see where the screwdriver went through the grommet.........????
  9. #9 Re: GOT MY BOOST GAUGE i have some Q's
    May 2008
    McHenry IL
    im going into the grommet where the ebrake cable goes through correct???? i dont see it "screwdriver" that i put through the grommet??? hummmmm?
  10. #10 Re: GOT MY BOOST GAUGE i have some Q's
    Joliet, IL
    i just made a new hole with a drill carefully and put in my own grommet....but if i had known there was a good grommet to use i would have....
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  11. #11 Re: GOT MY BOOST GAUGE i have some Q's
    May 2008
    McHenry IL
    im just wondering wtf does the ebrake cable come out into the firewall at im puzzled!
  12. #12 Re: GOT MY BOOST GAUGE i have some Q's
    Charles City, IA
    Exact opposite of where it goes into the firewall probally.
  13. #13 Re: GOT MY BOOST GAUGE i have some Q's
    May 2008
    McHenry IL
    iduh im saying with a light i still dont see it!
  14. #14 Re: GOT MY BOOST GAUGE i have some Q's
    Donating Users blowfishRus6's Avatar
    g.a.
    haha...
    shove that bish thru joe
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  15. #15 Re: GOT MY BOOST GAUGE i have some Q's
    I went through the passenger side grommet...IIRC there is WAY more space.
  16. #16 Re: GOT MY BOOST GAUGE i have some Q's
    GT Level Member Going Too Phast's Avatar
    There is a rubber plug to the left of the steering column where it goes through the firewall. I pulled that out and used a drill to put a small hole in it and then reinstalled the plug. The nylon tube will come out below the brake booster.
    .: 1998 GTP : 3.5 : PT : 1.9s : Intake : DP : Plog : 180* : 605s : UD WPP : STBs : 12" Brakes :.
  17. #17 Re: GOT MY BOOST GAUGE i have some Q's
    Charles City, IA
    Did any of you with autometers have problems getting the tubing threw the ferrel that goes in side the fitting at the gauge>
  18. #18 Re: GOT MY BOOST GAUGE i have some Q's
    May 2008
    McHenry IL
    Under booster thanks man ill try tomarrow night im going to sleep fyi im exhausted engine is in and bolted to trans saturday afternoon is start up wooooooohooo
  1. Need a Boost Gauge
    By SDGTP99 in forum General Tech Discussion
    Last Post: 09-27-2009, 08:20 PM
  2. Boost Gauge?
    By ChrisJ in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-05-2009, 01:56 PM
  3. MAP and Boost gauge
    Last Post: 07-02-2009, 12:49 PM
  4. Boost gauge...
    By WayneG99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2009, 08:52 PM
  5. Boost gauge on 03 gtp
    By brodyman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-04-2008, 08:06 PM
