Thread: Need a Boost Gauge
Results 1 to 20 of 31
  1. #1 Need a Boost Gauge
    Wichita
    I'm getting a Boost gauge cuz I'm tired of the fancy light-show in my DIC. It tells me nothing. What I need to know is; what kind do I get? where I get it? &, will it come with everything to hook it up?
  2. #2 Re: Need a Boost Gauge
    Joliet, IL
    glowshiftdirect.com.....7 color black series....40$ shipped comes with everything....great gauge for the price IMO im rocking one and love it...my only complaint is it goes up to 30psi instead of 20psi but thats just motivation to get it that high
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  3. #3 Re: Need a Boost Gauge
    Wichita
    Hmm. I might just get this. Gonna hafta get the A pillar pod cluster too. I'll go ZZP on that since everything else looks like cheap oily ABS plastic
  4. #4 Re: Need a Boost Gauge
    get a cause with a 20 psi scale. you want to know more of an exact reading then maybe not catching it on a 30 psi scale. you can MAYBE hit 20 psi on an m90 if its the winter and youre on a stupid small pulley. or you have a stock downpipe on a 2.8 or something retarded.
    get any mechanical gauge. they are all built the same. hell, you could realistically use any type of air pressure gauge if you get the right scale and hook it up correctly.
  5. #5 Re: Need a Boost Gauge
    Wichita
    Like this one then?: Autometer Phantom II Series 2 1/16 30-/+20 Psi Boost/Vac. Gauge [AUTO-7507] : Lethal Diesel, Your #1 source for diesel performance
  6. #6 Re: Need a Boost Gauge
    Charles City, IA
    SMGPFC Two Nipple General
  7. #7 Re: Need a Boost Gauge
    either of those would work. you just dont want an electrical one with a sending unit. you want one that youll have to tap into the vacuum lines.
  8. #8 Re: Need a Boost Gauge
    May 2008
    McHenry IL
    yeah theyre easier to install also lol im getting mine soon =] im picking up my volt and my trans temp gauges 2mrw also =]
  9. #9 Re: Need a Boost Gauge
    Banned - Busted For Scamming
    Feb 2009
    Autozone, $25 sunpro mechanical. Cheap, simple, effective.
  10. #10 Re: Need a Boost Gauge
    Apr 2009
    Springfield,Va
    I'm running AutoMeter Ultra-Lites. They match the interior fairly well at night with the amber lense cover. And don't look like ****ty advanced gauges. Not big on the carbon fiber look either to ricey. Have a oil pressure, trans temp and boost in the zzp a-pillar.
  11. #11 Re: Need a Boost Gauge
    Wichita
    Got a Cobalt 20psi gauge. I'll need 2 more gauges somwhere down the road since I got the ZZP 3 pod A-pillar.
  12. #12 Re: Need a Boost Gauge
  13. #13 Re: Need a Boost Gauge
    Jersey
    16' wrx sti- stock
  14. #14 Re: Need a Boost Gauge
    Auto Meter Ultra Lites here...plus...they light up the same color as the dash EXACTLY with the red bulb condom
    I now have boost on the bottom, then elec. oil pressure, followed by a volt meter up top...as that was my old setup.
  15. #15 Re: Need a Boost Gauge
    May 2008
    McHenry IL
    NICE im doing the same exact setup with the same series gauges LMAO nice nice ultra lite series but my order from the bottom of my zzp pod goes boost/vaccum then volt gauge then oil pressure ALL WITH RED CONDOMS duhh ha
  16. #16 Re: Need a Boost Gauge
    Wichita
    Yeah, the cobalt gauge turned out to be an AutoMeter. It's installed now. In park the car dosen't seem to get Boost until I really gas it. It goes up to 9psi. guess that's not too bad if the reading is acurate.
  17. #17 Re: Need a Boost Gauge
    youre not supposed to be able to build boost in park or in neutral when youre not moving.
  18. #18 Re: Need a Boost Gauge
    Wichita
    This I did not know. thx!
  19. #19 Re: Need a Boost Gauge
    Feb 2009
    9psi sounds right with a 3.4 pulley.
  20. #20 Re: Need a Boost Gauge
    Wausau, WI
    The gauge only goes up to 9 psi or your car only maxes out at 9 psi. This sounds a little low to me......of course with your " flow mods"(LOL) that you have done, who knows what it should be with that type of set up. I have 9 psi on my stock pulley sometimes. Usually it maxes out around 8, but I have seen 9 more than once.
  1. Boost Gauge?
    By ChrisJ in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-05-2009, 01:56 PM
  2. MAP and Boost gauge
    Last Post: 07-02-2009, 12:49 PM
  3. boost gauge and etc...
    By Charged97 in forum General Tech Discussion
    Last Post: 02-28-2009, 04:16 AM
  4. Boost gauge on 03 gtp
    By brodyman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-04-2008, 08:06 PM
