Thread: speedoand odometer stopped working
Results 1 to 11 of 11
  1. #1 speedoand odometer stopped working
    Detroit MI
    ok so i just bought a 99 gpgt today with 79,000 on it for 1100$. the speedometer stopped working two days ago and i dont know why. i tore apart the whole dash and didn't see anything really stick out to be wrong. i did nothing else. the tach works and so does the gas gauge and engine temp gauge. does anyone have any idea whats wrong and what to do to try and fix. and also i know its off topic but can i get a supercharger off a gtp and put it on my car, its a 3800 series 2. will it work or will it require severe modification
  2. #2 Re: speedoand odometer stopped working
    Banned - Busted For Scamming
    Feb 2009
    Check the VSS
    (Vehicle Speed Sensor)
  3. #3 Re: speedoand odometer stopped working
    Detroit MI
    Check the VSS
    how do i do that
  4. #4 Re: speedoand odometer stopped working
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    IS THE THE ONLY THING WRONG WITH IT? U got a great price.
  5. #5 Re: speedoand odometer stopped working
    Detroit MI
    Quote Originally Posted by a98gtp4u View Post
    yeah and it needs front struts
  6. #6 Re: speedoand odometer stopped working
    GEORGIA
    Wouldnt that 1 be on the tranny somewhere?
  7. #7 Re: speedoand odometer stopped working
    Wausau, WI
    First off you can get a supercharger and put it on your car, it is called top swapping. Your tranny will not like the extra power but how long it lasts depends on you and your driving style. If you are going to top swap it, be prepared to do the tranny within not too much more time depending on how much you use the new power. There is an entire stickied thread devoted to this process in the naturally aspirated engine area...http://www.grandprixforums.net/f17/t...lots-7763.html
    To get to the VSS.... you have to remove the right tire and engine splash guard to get to it. It has a wiring harness that goes to the sensor which is located on the top part of the trans where the CV drive axle comes out of it. Unplug the harness and there is one bolt holding it on, remove, swap it out, plug it back in and put the splash shield and tire back on. the right side is the passenger side by the way if you didn't already know. I would also guess that this is your problem.
  8. #8 Re: speedoand odometer stopped working
    May 2008
    McHenry IL
    dont complain about a gt for 1100
  9. #9 Re: speedoand odometer stopped working
    Charles City, IA
    Hit the top of your dash, I have to do it every once in a while.
    SMGPFC Two Nipple General
  10. #10 Re: speedoand odometer stopped working
    Detroit MI
    lol really. ok i'll try tomarrow
  11. #11 Re: speedoand odometer stopped working
    Charles City, IA
    It works for me. Only does it once every few months.
  1. Temp Gauge stopped working???
    By GXP05er in forum 5.3L V8 (LS4)
    Last Post: 08-10-2010, 07:37 PM
  2. Tranny Stopped working today. Couple ??'s
    By fergup in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-04-2008, 11:56 AM
  3. Boost Gauge Stopped Working
    By chipsdubbo89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-04-2008, 03:58 PM
  4. Cruise Control stopped working
    By 98gpgt98 in forum General Tech Discussion
    Last Post: 07-03-2008, 11:48 PM
  5. HUD Stopped Working After Huge Speed Bump
    By AmericaFcukYeah in forum General Tech Discussion
    Last Post: 05-24-2008, 12:13 PM
