Thread: Clean a Supercharger?
Results 1 to 14 of 14
  1. #1 Clean a Supercharger?
    Wichita
    I'm getting ready to put a new supercharger on my car. This s/c has been sitting in my shed for months so it needs cleaned inside. What do I use to clean it? Intake cleaner maybe? I need to take apart the case to do this?
  2. #2 Re: Clean a Supercharger?
    take it apart...remove the rotors...then spray out the snout with brake clean...wipe the rotors off if you want to...then spray brake clean on a towel and clean out the case...but you might as well port that one while it is apart...
    You still gonna ship me that case?
  3. #3 Re: Clean a Supercharger?
    Wichita
    Thanks! I can if you really want it. It'll be nxt week b4 a get it taken off & switched.
  4. #4 Re: Clean a Supercharger?
    Banned - Busted For Scamming
    Feb 2009
    Was there an actual problem with the port, or were people just saying there was?
  5. #5 Re: Clean a Supercharger?
    Wichita
    I'm not pleased with the results: 7psi on a 3.4". Sounds like a vacuum. Is slow.
  6. #6 Re: Clean a Supercharger?
    Feb 2009
    You take it back to them? How long have they been doing porting?
  7. #7 Re: Clean a Supercharger?
    Wichita
    Probly won't take it to them if im giving the case to BlueGTP91. If I remember correctly the guy(from FTW Motorsports; check out the website if you want lol) who did the port, said he'd ported by hand several times but my s/c was the first time he's used a jig. Dosen't explain why he opened it up the way he did. He opened up the triangle WAY to much & added the square to the tip of the triangle.
  8. #8 Re: Clean a Supercharger?
    Feb 2009
    All porting to the oulet should be done by a jig or cnc. Oh well hopefully it didnt put ya back too much.
  9. #9 Re: Clean a Supercharger?
    Jersey
    I used throttle body cleaner on the inside of mine, got it pretty clean. If you still use an egr, it will just dirty it up again anyways
    16' wrx sti- stock
  10. #10 Re: Clean a Supercharger?
    GT Level Member Going Too Phast's Avatar
    You want to be real careful cleaning the inside of the supercharger. I personally wouldn't touch the rotors with anything. Many cleaners will weaken or remove the coating (epoxy for Gen III) on the rotors which will make them (and the supercharger) become very inefficient. The rotor coatings are fragile enough after 10 years of use. The buildup from the EGR will tighten clearances between the rotors and housing and in theory will improve efficiency similar to what water injection does when sprayed upstream of the rotors. If you clean the inside of the housing there are two bearings that need to be greased. They need proper grease. Some people don't use the correct stuff and claim there is no issue, but even then you need to not just stick any old grease in there. The rotors turn at very high rpm. Bottom line is, it might not be as harmless and simple as you first think.
    .: 1998 GTP : 3.5 : PT : 1.9s : Intake : DP : Plog : 180* : 605s : UD WPP : STBs : 12" Brakes :.
  11. #11 Re: Clean a Supercharger?
    Feb 2009
    Quote Originally Posted by Going Too Phast View Post
    You see, this is just not true. Ive cleaned many of rotors doing the work i do, and no problems have come from it. The coating is epoxy powder, its not gonna break down unless you put some form of paint stripper on it. Brake clean and degreaser work well with scotch brite pads. If the coating chips it was on its way out anyways.
  12. #12 Re: Clean a Supercharger?
    Wichita
    I used brake cleaner. It did the job just fine. Not gonna worry about dirt; No longer have an EGR. As for the grease: What kind do I need to use?
  13. #13 Re: Clean a Supercharger?
    more people talking stupid things about the rotor coating. great.
  14. #14 Re: Clean a Supercharger?
    Wichita
  1. Clean gtp build
    By Davisgtp in forum Off Topic Discussion
    Last Post: 09-21-2009, 06:07 PM
  2. Clean Wheels
    By TML529 in forum Tires & Wheels
    Last Post: 03-16-2009, 01:59 PM
