Thread: roller rockers.....help....plz
Results 1 to 10 of 10
  1. #1 roller rockers.....help....plz
    SE Level Member bigdawg15005's Avatar
    pittsburgh,pa
    I was wondering if anyone knew whats the best size to use in order to maximize the use of my xp cam? Without bending or breaking anything..lol.... or should i just stick with the stockers,or just get the stock size rrs,or maybe 1.7s.? thanks in advance...just dont know what i should do and wanted to get you guys opinions.....Thanks
  2. #2 Re: roller rockers.....help....plz
    Donating Users blowfishRus6's Avatar
    g.a.
    you might have to mill down the collors on the heads if you go with a higher ratio (valve lock to seal clearence)
    easy way out, stick with stock ratio with rollers.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  3. #3 Re: roller rockers.....help....plz
  4. #4 Re: roller rockers.....help....plz
    Jersey
    you could use 1.7's with a vs cam
    16' wrx sti- stock
  5. #5 Re: roller rockers.....help....plz
    g.a.
    on the exhaust side, not the intake.
    its slow.
  6. #6 Re: roller rockers.....help....plz
    g.a.
    or vise versa, dont remember
    its slow.
  7. #7 Re: roller rockers.....help....plz
    pittsburgh,pa
    Thanks guys guess ill just stick with stock rrs....Anyone know how much better the l32,s heads are compared to the l67,s If they are better will they just bolt right up? I think i read somwere the valves had bigger openings and was just wondering if anyone knew,and about how much a used set are and were i could get a set. I checked all the salvage yards around my house and nobody has any. Thanks again for all the good info..
  8. #8 Re: roller rockers.....help....plz
    g.a.
    they do have bigger valves. thats about as much as i know thats diffrent. yes they will bolt up to your block.
    its slow.
  9. #9 Re: roller rockers.....help....plz
    Charles City, IA
    Call ed morad IIRC some one got a set for $250
    SMGPFC Two Nipple General
  10. #10 Re: roller rockers.....help....plz
    SE Level Member Supercharged's Avatar
    Round Lake, IL
    Quote Originally Posted by bigdawg15005 View Post
    You will either have to use an L32 LIM as well or you will not be able to bolt your supercharger on. If you are going to spend that money, you might as well go to a Gen V while you have it down.
  1. which double roller
    By QwikGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-05-2008, 06:52 PM
  2. roller rockers ?
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-23-2008, 12:28 PM
  3. Roller Rockers
    By IndeedSS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-19-2008, 05:49 PM
