Thread: Do I have bad axles? whirling/huming noise.
Results 1 to 5 of 5
  1. #1 Do I have bad axles? whirling/huming noise.
    Apr 2009
    methuen
    To cut to the chase.. I have replaced the wheel bearing, didnt change the sound. Put my stock tires back on, still there. When I am driving at speeds above 30mph, I get this constant humming . when I cut the wheel to the right I am loading the wheel on the left and it gets like a pulsing/humming noise. When I turn to the left still there but not as loud. At highway speeds its quite. All other wheel bearings were replaced with timken about 5 months ago, they had play in them, but the wheel that I just replaced didnt have play. And replaced it figuring thats where the noise was coming from. I have 120k on the axles. Do you guys think it may be the axles going bad? Check boots no rips. the boots were replaced 3 years ago with upgraded boots and grease ,because they were slinging grease. The CVs checked out ok at the time. Im just a bit lost here. TIA I also posted this over at clubgp.
  2. #2 Re: Do I have bad axles? whirling/huming noise.
    Oct 2008
    Northern Illinois
    You SURE all the wheel bearings are in good condition?? You pretty much just described exactly what it sounds like when one goes bad.
  3. #3 Re: Do I have bad axles? whirling/huming noise.
    Apr 2009
    methuen
    • To my knowledge, checked them over real well. I just replaced that side, because I thought thats where the noise was coming from, there was no movement in the bearing. the other bearings maybe have 10k on them, timken brand.
  4. #4 Re: Do I have bad axles? whirling/huming noise.
    SE Level Member Supercharged's Avatar
    Round Lake, IL
    Sounds like a wheel bearing...just because its new doesnt' mean it can't go bad.
  5. #5 Re: Do I have bad axles? whirling/huming noise.
    Oct 2008
    Northern Illinois
    Yeah if you curbcheck real bad or hit something real hard that will throw it off.
  1. Don't buy these axles!!!!
    By 01RedfireGT in forum General Tech Discussion
    Last Post: 06-29-2009, 11:32 AM
  2. This noise
    By pontiackid in forum General Tech Discussion
    Last Post: 06-11-2009, 11:41 AM
  3. Axles
    By starscr33m in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2009, 09:59 PM
  4. Axles, hubs and Halos - oh my!
    By MnRedGP in forum General Tech Discussion
    Last Post: 02-08-2009, 02:08 PM
  5. Converter stall?Stock axles?
    By PWNED in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-14-2008, 11:51 AM
