Quote Originally Posted by BackInBlack View Post
Well, the FIRST thing you need to know is that not all model year DICs are interchangeable. 1997 and 2003 are unique to themselves. 1998 thru 2002 will interchange. The 1997 cars require an additional wire be tapped into the instrument cluster header. You can pull a pin from your analog DIC header and insert it into the instrument cluster header in the appropriate position. Below is the wiring diagram for all the years. Note the 97 changes on the right hand side.
I think I have a 97 (since the digital has a tire pressure light above the low trac light). What specifically do I have to do to make it work? Where am I suppose to put a new wire into what instrament header, why? Anybody know specifics? I'll give it a try and let you all know how it goes. maybe this explains the flashing zeros.
