Thread: Need For Gen V swap ?
Results 1 to 12 of 12
  1. #1 Need For Gen V swap ?
    GT Level Member Meemperor's Avatar
    Toronto, ON, Canada
    Just wonder what EXACTLY I need for the Gen V swap. We're swapping off a S2 IC gen III for a S2 IC and Gen V March 1st and I don't want take toooo many trips to the local dealership.
    Got :
    LIM gaskets
    Coolant Elbows
    S/C Gaskets
    Oil
    RTV
    TB adaptor ...
    Anything else I need ?
    Lumpy Gen 3
  2. #2 Re: Need For Gen V swap ?
    Bastard Reptile's Avatar
    Kansas City, MO
    You got the stock bolts for the GenV?
    You will also need to re-route your pcv system, tap it back into the intake tube, and make a block off plate for the evap solenoid on the GenV. Other than that, have fun!
  3. #3 Re: Need For Gen V swap ?
    Hoffman/Schaumburg, IL
    If they aren't part of the SC gasket there are two coolant o-rings.... Definetly post up some pics when done....maybe even make a write-up
  4. #4 Re: Need For Gen V swap ?
    Toronto, ON, Canada
    Quote Originally Posted by Reptile View Post
    AH HA. That's exatly the info I was looking for. That damn PCV. Since these IC's are the old ass ones there is no function PCV so that makes life somewhat easier. I have all the IC bolts for a Gen V set up. The block off plate for the evap selenoid is what I was really looking aht here !
    PS. I'll do a write up I geuss... Or I'll just dictate what I'm doing to someone and they can write it while I'm busy working. lol.
    Lumpy Gen 3
  5. #5 Re: Need For Gen V swap ?
    Wichita, KS
    Some useful info that might help you out.
    ClubGP Message Forum troubleshooting
    ~F~
  6. #6 Re: Need For Gen V swap ?
    Oklahoma
    I knew I liked you 02BlueGT, asking for the write up.
    Definitely do a write up if you can. Id like to see written and visually documented write ups on anything even as simple as an air filter change, oil change.
  7. #7 Re: Need For Gen V swap ?
    why do you need a write up for this? the only "hard" part is adapting the pcv.
  8. #8 Re: Need For Gen V swap ?
    Some people like to see what they are getting into before they do it.... and anyway, the more write-ups the better
  9. #9 Re: Need For Gen V swap ?
    SE Level Member WillOverkill's Avatar
    Feb 2008
    Get yourself an EGR blockoff plate from ZZP and it'll work well for the EVAP, although when I did my GenV swap on my 98 I kept the GenV's EVAP solenoid.
    If you don't have the PCV inlet in the IC, just cap off the vacuum port, and be sure to run a good breather setup. If you've seen Jesse's car, I like to get the push-in 1 1/4" chrome breathers (Edelbrock or Mr Gasket brand), along with a Mr Gasket grommet that has baffles to prevent oil blowout, and drill the oil filler cap for the grommet.
    Ensure you have the GenV IC bolts.
    If you're reusing the GenIII IC and modifying it, you'll need to epoxy some of the GenV vacuum ports, hold the plate up to the bottom of the blower and you'll see them. Epoxy putty FTW.
  10. #10 Re: Need For Gen V swap ?
    Toronto, ON, Canada
    Quote Originally Posted by WillOverkill View Post
    Nah Gen V IC and I have all the bolts for it. Breather ? pffft. I'll jsut drill holes in the the vavle covers.
    Lumpy Gen 3
  11. #11 Re: Need For Gen V swap ?
    Feb 2008
    Drill holes in the valve covers eh, Shimmy style FTW?!?
    Get Your 3800 Overkilled @ http://www.getoverkilled.ca
  12. #12 Re: Need For Gen V swap ?
    Toronto, ON, Canada
    FTW.
    IIRC he drilled it in the fill cap
    Lumpy Gen 3
  1. Seat Swap: 04+ to 97-03[*]
    By LowlyfeGTP in forum How To Write-Ups/Tech Tips
    Last Post: 12-25-2013, 03:32 PM
  2. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
  3. 97.5 pcm to 98 swap?
    By monte0 in forum PCM Tuning
    Last Post: 01-07-2008, 10:09 AM
  4. Top Swap Section
    By indy99gpgt in forum Forum Bugs/Suggestions
    Last Post: 12-27-2007, 05:53 PM
  5. 1992 Cadillac STS L67 Swap
    By Trannyman95 in forum Transplants
    Last Post: 12-13-2007, 04:34 PM
