Thread: Downpipe
Results 1 to 13 of 13
  1. #1 Re: Downpipe
    Wausau, WI
    you cant get a swivel socket in there?If you still cant get to it... take off the dog bones on the front of the motor and tie a ratchet strap onto the rear of the motor and pull the motor forward.....this will give you plenty of clearance. Not sure what exactly is in the way, but you could also remove the sway bar if that helps.....but you are probably tight on room at the top of it...
  2. #2 Re: Downpipe
    Apr 2009
    Annapolis, MD
    The bolt is to long for the size of the socket i can fit over it, the sway bar is in the way maybe i can remove it for some room but moving the motor seems like a bit of an overkill.
  1. which downpipe
    By superv6 in forum General Tech Discussion
    Last Post: 04-19-2009, 06:41 PM
  2. ZZP downpipe
    By offroadfury6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-27-2008, 06:29 AM
  3. Zzp downpipe again.
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-24-2008, 10:07 AM
