Thread: Cone filters
Results 1 to 18 of 18
  1. #1 Re: Cone filters
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Quote Originally Posted by bat119 View Post
    I read the instuctions for installing the K&N filter system and it involves remounting the sensor inside the filter box, if I was to make a transition from the filterbox (where the old filter is now ) to the back of the cone filter enclosing the entire cone, would this have the same effect? (without touching the sensor inside the box)
    I wouldn't get the K&N system, too expensive and does not isolate the filter from the underhood temps.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  2. #2 Re: Cone filters
    St. Louis Mo.
    Quote Originally Posted by IndeedSS View Post
    Aye I would agree with Lee on this one. Its not a TRUE CAI system. Its just basically a heatshield and nothing more. The filter is still vulnerable to engine bay's heat. At least the WizAir and lesser the Thrasher would be keep things cooler in the longer and might cost a bit more, but its so much more worth it!!
    The reason why I said "lesser the Thrasher" is because Reptile did a check of my air intake temp with my Thrasher CAI unit that was recovered with reflective heat wrapping and the temps were still way to high even for what the stock air box does. Thus the WizAir would be the wiser choice.
    Just my 2c on that topic
    James Shafer
    St. Louis MO
  1. Tefba coolant filters GROUP BUY !!
    By bayareagtp in forum Group Buys
    Last Post: 04-07-2008, 10:43 AM
