Thread: wooooooo
Results 1 to 20 of 22
  1. #1 wooooooo
    SE Level Member m3ta77ica's Avatar
    Illinois
    so i pulled out of dairy queen n i gave it su gas n the s/c wound up and really didnt go back down all the way n i turned it off then started it bak up then when i turned the wheels left to right it made it louder makin a big woooo noise. then drivin home it did it the whole way and it was alor luder when i got on it so what the hell is wrong??????/ i figured a belt cuz of the s/c and the steering but it all looked fine
    plz help
  2. #2 Re: wooooooo
    in a house
    I've read this 5X and have no idea what the hell your even asking? What do you mean the s/c wound up and wont go back down? If its a groaning noise when you turn your wheels then I suspect your power steering fluid is low?
  3. #3 Re: wooooooo
    Charles City, IA
    x2 English please.
    SMGPFC Two Nipple General
  4. #4 Re: wooooooo
    Jan 1970
    Maquoketa, Iowa
    Its that whoo whoo
  5. #5 Re: wooooooo
    Donating Users chico's Avatar
    Sounds like your car wants you take it on the Jerry Springer ,seriously your post makes no sence atall try to explain your problem so the masses can understand and maybe help your woo hoo problem.Chico.
    04 gto stock,97 GPGT l-36 block diamond pistons ,l-32 rods ,custom comp cam grind,HS 1-7 RR, p&p heads, SS IC,SS M-90 3.5" ,4t60eHD,from Gonzales TX.
  6. #6 Re: wooooooo
    Wausau, WI
    Just turning your wheels can not make the supercharger louder. It is not possible. Please give us some more detail of your problem stated clearly. Thank You....
  7. #7 Re: wooooooo
    Illinois
    it was late sry. lol i hit it pullin out lastnight and i herd the super wind up and it seemed not to come back to idle. then when i turned the wheels it made a noise that sounded like the s/c. if that makes ne more sence
  8. #8 Re: wooooooo
    Power Steering.
  9. #9 Re: wooooooo
    Ever checked the PS fluid? I might be wrong..it could be blinker fluid, but that's less likely.
  10. #10 Re: wooooooo
    Wausau, WI
    I would second the power steering........any noise during turning is most likely in the steering.........not sure on the blinker fluid though.......always use synthetic blinker fluid. It will perform better......
  11. #11 Re: wooooooo
    Illinois
    so i got gas today and now its not makin noise wtf.... im so confused
  12. #12 Re: wooooooo
    WOO WOO! you shouldnt be sleepin in da mornin you should be up eatin brefkast or sumfin.
  13. #13 Re: wooooooo
    Wausau, WI
    Quote Originally Posted by m3ta77ica View Post
    well........I doubt that those issues are related to gas........but you should be happy......problem solved.
  14. #14 Re: wooooooo
    GT Level Member skidoojames151's Avatar
    seattle
    100% ON ADD SOME power steering fluid...i can confirm this if you take a hard turn and it does the sound again...if so add some fluid
  15. #15 Re: wooooooo
    Jan 1970
    Maquoketa, Iowa
    its fo decoration... dats it n dats all, jus fo decoration
  16. #16 Re: wooooooo
    Wausau, WI
    did I miss something? Since when is metallica gangsta?
  17. #17 Re: wooooooo
  18. #18 Re: wooooooo
    Illinois
    it makes the noise a lil now
  19. #19 Re: wooooooo
    Apr 2009
    Wausau, Wisconsin
    Bubb Rubb sez: It goes WOOOOO WOOOOOO. Ya no yo drivin dow da streetz and yo ride go WOOOOO WOOOOO eribody look at cho.
    http://www.youtube.com/watch?v=n79jSzKA0L8
    Haha sorry I'm just playing.
  20. #20 Re: wooooooo
    Wausau, WI
    did you check the power steering level?
    It is not easy to get to, but it is better than having to replace the steering....
