Thread: ls1 throttle body linkage ...
Results 1 to 7 of 7
  1. #1 ls1 throttle body linkage ...
    indy
    i iam n the middle of a top swap on my bonneville. i build corvettes so the ls1 tb was what i choose just cause wanted ls parts on it. so i mocked up the intake after the head swap and realized the linkage is backwards for our use and cant seem to find any info on a fix (which looks like is to rotate the linkage 180 degrees)...anyone got links or can tell me what you guys are doing?
  2. #2 Re: ls1 throttle body linkage ...
    Pretty sure you have to flip the linkage over and reweld it.
  3. #3 Re: ls1 throttle body linkage ...
    Reweld it?
    Isn't this usually a Gen V thing ...isn't that where it's normally done because the bolts are a square pattern?
  4. #4 Re: ls1 throttle body linkage ...
    indy
    yeah i was having no luck finding info on how sooooo... i just started tearing it apart...
    ls1 throttle body set up for bonn....
    remove tps and iac sensors so don't get hurt
    remove throttle body blade by removing two screw holding it in
    take hammer and knock the linkage shaft out thru the tps sensor opening. there is a washer holding it in so it will take a few wacks just be careful not to damage the end.
    this is what you are after...
    next you will have to grind the end off of the linkage end so you can remove the cruise nub and the cable guide.
    once they are removed rotate then 180 degrees and slid back on. by only flipping cable guide and cruise nub the throttle stops stay in normal location. then reweld the shaft to the linkage
    clean end back up with grinder and it ready to go back together
    thats it. here it is insatlled
  5. #5 Re: ls1 throttle body linkage ...
    GTX Level Member 03GTPLE's Avatar
    Tyler, TX
    I've read on here that the Northstar TB has the linkage flipped.
    2003 White Grand Prix GTP Limited Edition
    - 3.4 pulley, tune by Boostd1/CLINT@AIR, Short Ram Intake, PLOG, 3" ZZP Downpipe, AL 104's, 180* t-stat, Impala STB & 12" cross drilled/slotted/zinc washed rotors, DDM HID's, and put in a heads up display for now...
  6. #6 Re: ls1 throttle body linkage ...
    Wausau, WI
    thanks for helping the next guy......LOL
  7. #7 Re: ls1 throttle body linkage ...
    Yup...told ya...rewelded.
    Glad you got it fixed man, hope my pic helped.
  1. LS1 or N* Throttle Body
    By 2000GTP2708 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-25-2012, 08:19 AM
  2. LS1 Throttle body
    By Clar2478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2012, 05:16 PM
  3. Throttle body in an 08
    By zenman400 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-12-2009, 09:01 AM
