Quote Originally Posted by GeddyLee View Post
Ok just got back in from outside. I rehooked everything up but nothing still turns over. I got spark and you could hear the door locks activate when the negative was reattached to the battery. But when I go into the car to try and start it up, I put the key all the way forward to start it. Everything goes blank. The DIC LEDs disappear and everything. But when I release the key, back to the middle position before lock, where you can remove the key, the LEDs in the DIC come back.
I also watched my VOLTS gauge on my pillar pod and it did not move or come on, nor did any other other gauges.
I am gonna pull the battery and run it upto Autozone to test it to see if that might be the culprit. Its the original battery that came with the car, and its an 03, so the battery has had 5 years on it. I know that is the "iffy" time for batteries to maybe go?
Any suggestions??
Also testing the MAIN fuse panel in the engine well revealed that some fuses would light up completely on BOTH sides where you can put the tester on it. Others would only light up on one side. And I had some that did not light up at all when testing, but when pulled they appeared to be intact at the Horseshoe arch within the fuse.
Any clues on that?
Thank you all again!
well... there are some EXTRA fuses in the main fuse box... they're spares, no current for them... did you look at the diagram?
perhaps is ignition switch?
