ok so i read the safely mmod your 3800 thread and i wana get new plugs and wires. prolly just gona get the autozone brand wires. but for plugs which are the better? Autolite 104's or NGK TR55's? opinions and comments will be appreciated. thanks
Autolite...Copper plugs + Boost = Win.
Aren't colder plugs one of the last things you generally get when modding?"
If you have an OReillys, I recommend getting there Borg/Warner wires which include a Lifetime warranty..
The Duralast and Bosh wires that AZ sells also have lifetime warranties. I personally have had a few problems with the BW wires coming apart at the boot even with di-electric grease in the connection. I still use them, though (already been paid for).
^ thats what i currently am. i plan on doing a top swap here soon though after i move an get on my feet. i have an OReillys around me so ill look into them. i plan on a top swap, 3" dp with new exhaust and headers, and prolly a cam. but for now im just n/a for awhile =/
ummm...you dont need both a dp and headers...headers come with it and a deleted u-bend.
if you are na yet.........in my opinion just stay with the stock platinum plugs. You dont need copper for best performance until you have the SC and you dont need to drop heat ranges( i.e. autolite 104's) until you drop pulley sizes from the stock supercharger. So run the stock platinum's until you do your topswap and then you can change your plugs. If you go colder than you need to, you will lose MPG's big time.........the colder plugs are just used to combat knock retard with the superchargers. If you are getting headers, they come with their own down pipe, and if you dont want headers then use the Plog/ Downpipe setup...
so if i am n/a, and plan and staying n/a forever, are there any plugs that i could benefit from, or should i just stay with "stock" rated ones?
platinums are fine for na............i prefer ngk personally.......stock rated heat range.........
AZ wires suck. bottom line i still have them on and i regret it ha
hogan 3inch DP u bend delete ,180*tstat, autolite 104s, LED interior, 4" FWI, 2000watt system, bullitt rims, zzp pistons, pems, alt rewire, thrush muffs, 3.4 zzp mps, transgo shift kit, triple edge performance trans. autometer triple pod :SOON: urlosn HPT PCM tune, HEADERS, 1.9's| « Previous Thread | Next Thread » |
