Thread: rollers or modified.
Results 1 to 20 of 39
  1. #1 rollers or modified.
    Donating Users
    Plainfield, IL
    gonna have a 3.4 and tune with in a week or two finally next will be rockers....
    should i go 1.9 modified, 1.84 yella terra rollers? maybe 1.95?
    will i see a significant diff between them ?
    id rather do modified as it is cheaper...but if rollers are much better ill wait and save....dont want a cam so dont say cam it....i wanna go 12's ron vogel style on a stock cam plus rollers are a DIY for me....i have the knowledge to do the cam install but dont wanna deal with all that bullshyt and money...im leaning toward 1.84 RR because i can use stock springs or cheap l76 springs....
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  2. #2 Re: rollers or modified.
    If your getting rollers just get 1.90's and #90 Springs (LS6)...IIRC they are cheaper anyway and work just as good. I had 1.84's and loved them...but...I love my cam more
  3. #3 Re: rollers or modified.
    Outer Space
    i got the 1.9s from zzp and #105 springs. Been running them for 30k miles without and issue.
    02 GTP 13.6 @ 100mph - SOLD
  4. #4 Re: rollers or modified.
    Aug 2008
    Long Island, New York
    get rollers... its worth it
  5. #5 Re: rollers or modified.
    TDCRacing
    Guest
    Rollers. they offer more valvetrain stability and offer YOU more power because of the reduced friction that is obtained from them being a ROLLER rocker.
    With the ZZP modified rockers the actual RR varies highly. Wich is not good.
  6. #6 Re: rollers or modified.
    ive had no problem with my modified 1.9s. they work well, but if youre looking for an all out rocker build then youre going to want to get rollers. if i were to get rollers i would spare no expense and get the 1.95s.
  7. #7 Re: rollers or modified.
    I saw 1.9 rollers, with a minimum of 90# springs if not 105#..
  8. #8 Re: rollers or modified.
    GT Level Member 05SS45's Avatar
    Jan 2009
    westport maSS
    if i went rockers i would go roller's! good luck!
    Going back to stock *GRANT built trans BLOWN w/17k*
  9. #9 Re: rollers or modified.
    Jersey
    I have y/t's 1.9's. I run L76 (g8 gt) valve springs. They're a little cheaper.
    16' wrx sti- stock
  10. #10 Re: rollers or modified.
    Charles City, IA
    I have modded rockers. If I were to do it again I would get rollers.
    SMGPFC Two Nipple General
  11. #11 Re: rollers or modified.
    Moore, Oklahoma
    I've been running Intense 1.9 Stock/Modified Rockers for many years now and i've put nearly 100,000 miles with them in my car, so far so go. I later upgraded to 105# Springs/Retainers which upgrading the springs is an ABSOLUTE must for ANY 1.9 rocker build roller or modified, stock shift points or not. If you don't believe me do some research on ClubGP about spring failures with rockers. I was one of those guys, though I was lucky and cought it in time before potentially dropping a valve.
    I plan on running my setup for the rest of my motors life, its got 170,000 miles on it, its too late to do a cam in it now.
    Back in the day when I did rockers all that was availible was stock/modifed. Nowadays if I were to do a rocker build again i'd go with Yella Terra 1.95s Rollers honestly. But theres nothing wrong with stock/modified rockers either as you can see.....
    Shawn W. Larsen
  12. #12 Re: rollers or modified.
    Jan 2009
    westport maSS
    Quote Originally Posted by 99prixgt View Post
    im interested in getting L76 springs when i do a cam. around how much are the springs & where can you get them the cheapest?
    ty
  13. #13 Re: rollers or modified.
    Oxon Hill, MD
    I'm thinking about getting the 1.95 YTs for my top swap build. Are there any reasons not to go with the 1.95s? I've already got L76 springs and LSx retainers.
  14. #14 Re: rollers or modified.
    TDCRacing
    Guest
    as long as you do not want a cam in the future then there is no reason at all. For a rockerd car they will be your best bet.
  15. #15 Re: rollers or modified.
    Might as well market off a 3.25:1 Roller Rocker Parker...make that bastard open so far the valve falls out LMAO!!
  16. #16 Re: rollers or modified.
    TDCRacing
    Guest
    I'm on it...
  17. #17 Re: rollers or modified.
    Jan 2009
    westport maSS
    so no price's or place's to get L76 springs lol!
  18. #18 Re: rollers or modified.
    It's a GM spring, that's cheap and readily available at dealerships from what I've heard on the street.
    Another low cost choice is looking to ebay for LS6 springs. Usually there is a set or two going very cheap. Only thing there is you shouldn't use them on a 96 or 97 head because of the shape.
  19. #19 Re: rollers or modified.
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Quote Originally Posted by 05SS45 View Post
    Be very careful, the max lift on the L76 springs isn't very high. If you're going anything bigger than a VS or NIC cam, you need to look elsewhere.
    2001 Buick Regal LS - Almost Stock
  20. #20 Re: rollers or modified.
    ^^THAT. Is the reason why I went with LS6 Yellow #90's.
  1. My modified headlight!!
    By Malefic_GP in forum General Tech Discussion
    Last Post: 09-27-2008, 11:27 PM
  2. Modified '97 TB?
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-08-2008, 10:57 PM
