Thread: DIY catback install?
Results 1 to 6 of 6
  1. #1 DIY catback install?
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    My son and I are going to install a GMPP catback on his 99 GTP. His Hoganperformance DP was recently installed so the bolts SHOULD be easy enough to remove.
    What is the best and safest way to gain enough under car access to be able to install the catback?
    On my SER, I swapped out the GReddy catback with the stock many times. I just jacked up the right side of the car and slid my ramps under the front and rear tires. Can this be done on a GTP w/o hurting anything? Is there a better way?
    Other than spraying the rubber hangers with PB Blaster, is there any other tips to make this quick and easy?
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  2. #2 Re: DIY catback install?
    Oklahoma
    If you have ramps, why not drive the car up on the ramps for the front tires and just jack up the rear end and put it on jack stands. I would think that would give plenty of clearance for everything that needs to be done.
    I would spray down any bolts you need to take loose with PB blaster even if they were recently installed just so you know they will come loose easy enough.
    Why dont you just send me that GMPP cat back and I'll do a long term test for ya and make sure everything is good.
  3. #3 Re: DIY catback install?
    Topeka, KS
    When i installed mine i just jacked up the rear and put it on jackstands while the ebrake was on. Installed it in about 20 to 30 min. Like Scotty said though let it cool down and pblaster the bolts and let soak. Other than that its all cake work.
  4. #4 Re: DIY catback install?
    GrandPrix Junkie
    Saraland Alabama
    Quote Originally Posted by rynoman03 View Post
    just curious why you had the ebrake on since the rear wheels were in the air? I too just jacked up the back, but the side would work also depends on if you like sliding on the ground or not
  5. #5 Re: DIY catback install?
    St Louis MO
    Thanks guys. I dont like (trust) jack stands, however I realize it is just a phobia of mine. I could back up my ramps but would still have to slide under the car to get to the resonator to DP bolts. However, it may be worth giving the rear ramps a shot versus lifting the side up.
    Oh and I'm wondering about the ebrake too.
    2010 Camaro SS LS3
  6. #6 Re: DIY catback install?
    Bastard Reptile's Avatar
    Kansas City, MO
    Ramps work pretty well, but sometimes they just don't get the car high enough.
    I did Alex's car with jackstands, and wheel chalks. Whatevery you do, take every possible safety caution you can. Block both front wheels and set your e-brake if you use ramps. you simply can't be careful enough.
    And FWIW, WD-40 actually works better on the rubber isolators.....it's just got a little more "slick" to it if ya know what I mean. Take it down from the back to the front.....pop the mufflers loose, then mid way, and finally the front hanger. Make sure Drew holds the mufflers up obviously...it makes it a little easier to handle...then reverse it to put it back on. I think I did it in like 30 minutes even with the exhaust hot from his trip up from STL.
  1. Stereo INSTALL.....need help
    By TMOTA503 in forum Audio, Security & Visual Electronics
    Last Post: 02-28-2008, 11:01 PM
  2. 1.9 modded rocker install
    By ExpyGator in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2008, 12:38 PM
  3. easiest shift kit to install ?
    By bayareagtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-26-2008, 09:18 AM
  4. ZZP Fuel Logs Install [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 01-17-2008, 12:28 AM
  5. did I do an install on your gp today?
    By s1795so2 in forum Midwest
    Last Post: 01-06-2008, 06:56 PM
