A failing ignition control module could produce the symptoms you're experiencing. You can take it to an Auto Zone and have it checked for free.
Also, a bad MAF can cause a poor idle and stalling problem. Un-plug it and see if anything changes.
I appreciate your posts guys.. I'm gonna do this tomorrow
let us know how it works......or doesnt.....
So far nothing.. I can't seem to find the Ignition Control Module in my car
The ignition control module is the piece that the coil packs bolt onto.....do you know where they are? You will have to swap the coils over to the new ICM if you are replacing this........I have the three set second edition set of the W body guide for my year grand prix from GM........the three editions total are like six inches thick......they are worth their weight in gold.
step by step directions for everything with pics. Picked them up on e bay for like thirty bucks.......get a set if you can find them
you find it?
Not the module... and not the MAF....
you check the idle air control yet? coils all good?
not sure.........just another shot in the dark...
is the cat clogged up? my daughters mustang would run, lose power then die. cool down for 10 minutes and same problem over again, so i cut it off and no more problem!
Just barely touch the throttle while trying to start it. If it starts and runs like that, but dies when you let off the throttle, then the IAC is the problem.
Did you try changing the fuel filter yet?
wait a minute.. isn't the IAC connected to the MAF or close to it? I think I checked it already and it does spring out.
So I guess that cancels that
Just a shot in the dark but I know you said you replaced the fuel pump and filter but is there a way you can make sure the injectors are firing? I saw one mentioned to try starting the car with the pedal slightly depressed to see if it stays running. Did it? You said the spark was good so Im still stuck on the fuel theory. Good luck.
i hope this diagram helps you locate the IAC. though you should be getting a CEL with code P0506 or P0507 if there is an issue with it. 506 is IAC system rpm low and 507 is IAC system rpm high.
