if you found a good tuner it is possible to get close to your goals just by modifying the pcm.....but you will definitely be able to get there safely if you put all of the correct supporting mods on in the correct order. If you just slap a pulley on with no mods and try to tune it you will probably wreck your motor........fwiw.
