Thread: Right-Front Grinding Noise
Results 1 to 6 of 6
  1. #1 Right-Front Grinding Noise
    SE Level Member cowmilker08's Avatar
    Kendallville, IN
    On the woman's car there has been a subtle vibration and an increasing noise. I guess grinding probably isn't the correct word but it sounds like metal knocking on metal. The car is a 97 with 109k on the clock. The noise increases with ground speed not engine speed. Also if you turn slightly to the right the noise ceases. I am thinking that it is probably a CV joint, but to be honest i don't know much about these cars. Trucks are my thing. I am just looking for some advice and/or ideas before I start tearing it a part.
    1997 Grand Prix GT 118,000 miles - Stock (fiance's)
    1996 Ford F-250 HD 7.3L Powerstroke Turbo Diesel , 3 1/2" Straight Pipe Exhaust, K&N air filter (soon to go), 203 degree T-stat, Torque Converter Lock-up Switch + Exhaust Back Pressure Valve Switch = Exhaust Brake , 243,000 miles
  2. #2 Re: Right-Front Grinding Noise
    GT Level Member Swash's Avatar
    Excelsior Springs, MO
    Quote Originally Posted by cowmilker08 View Post
    You've diagnosed it pretty darn well. It is either the half shaft, or the wheel bearing. If it's kind of a "growling" noise - sort of like extreme road noise from crappy tires, then it's a wheel bearing/hub. Take a look inside the wheel well and see if you see any grease on the control arm, sway bar - well, generally just about anywhere. If you see it - that's because the CV boot is puking it out for some reason - likely a tear.
    HTH
    -Swash
    I'm sorry, I can't hear you over the sound of how awesome I am...
    2004 IBM/Black/A4 GTO -- 1 of 273 - and the slowest
    2002 Galaxy Silver GTP - a few mods - sold
  3. #3 Re: Right-Front Grinding Noise
    Charles City, IA
    Jack up the front of the car and more the tire side to side and up and down. If it feels loose and the strut is not moving with the wheel it is a wheel bearing.
    SMGPFC Two Nipple General
  4. #4 Re: Right-Front Grinding Noise
    Or a tie rod...
    To be more specific - grab the tire at 9 and 3 o'clock and try to move the tire/wheel. Do the same at 12 and 6 o'clock. If it moves much at all - you either have A)loose lug nuts (don't laugh, I've seen it) B)worn tie rod C)bad hub (in this case, it would be really really bad)
    -Swash
  5. #5 Re: Right-Front Grinding Noise
    Feb 2009
    Marengo
    Cowmilker08,
    Did you fix it yet? My 2001 GT with 150K miles is doing the exact same thing, including that part about the noise reducing or almost going away during a right turn, or even lane change for that matter and both front bearing assemblies were replaced 3k miles ago. Wheel bearing change helped, they were sloppy, but the noise didn’t go away. I think I’m probably going to replace both CV half shafts this weekend. By the way, all 4 tires are new, so I’m confident their not the source of the noise.
  6. #6 Re: Right-Front Grinding Noise
    Kendallville, IN
    Sorry, i forgot to post the end of the story.
    A new hub assembly fixed the noise.
  1. Clunking noise in front end 04 gtp!!!!
    By justin98 in forum General Tech Discussion
    Last Post: 11-08-2011, 03:19 PM
  2. Pulley making metal grinding noise??
    By abuckley1290 in forum General Tech Discussion
    Last Post: 07-14-2010, 10:46 PM
  3. Roar noise from front end
    By markh in forum Brakes/Suspension/Chassis
    Last Post: 07-11-2009, 01:37 AM
  4. Grinding noise coming from my engine
    By zeppelinrocks18 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2009, 04:24 PM
  5. Grinding from right side front plus more
    By 99BluGP in forum Brakes/Suspension/Chassis
    Last Post: 06-11-2008, 10:15 AM
