Quote Originally Posted by cowmilker08 View Post
On the woman's car there has been a subtle vibration and an increasing noise. I guess grinding probably isn't the correct word but it sounds like metal knocking on metal. The car is a 97 with 109k on the clock. The noise increases with ground speed not engine speed. Also if you turn slightly to the right the noise ceases. I am thinking that it is probably a CV joint, but to be honest i don't know much about these cars. Trucks are my thing. I am just looking for some advice and/or ideas before I start tearing it a part.
You've diagnosed it pretty darn well. It is either the half shaft, or the wheel bearing. If it's kind of a "growling" noise - sort of like extreme road noise from crappy tires, then it's a wheel bearing/hub. Take a look inside the wheel well and see if you see any grease on the control arm, sway bar - well, generally just about anywhere. If you see it - that's because the CV boot is puking it out for some reason - likely a tear.
HTH
-Swash
