Thread: 3.4 is on! belt slip solved still knockin :)
Results 1 to 20 of 29
  1. #1 3.4 is on! belt slip solved still knockin :)
    Donating Users
    Plainfield, IL
    ok guys so i have the mods listed in the sig soon to be accompanied by a 180 stat.....im completely untuned at the moment and im seeing like 5*-6* of kr! will a tune and colder stat kill most of that? ill prob end up going into trims and maf tune if necessary..
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  2. #2 Re: 3.4 is on!
    Banned - Busted For Scamming
    Feb 2009
    Told you to wait... you need an intercooler now!!
  3. #3 Re: 3.4 is on!
    Donating Users
    Plainfield, IL
    well i just realized my vac feed to the fuel pressure regulator wasnt on for the first drive with the pulley so im going to work now ill let you know if its any better....if i cant kill the kr ill just get a 3.5 or 3.6 for now thank god i went MPS
  4. #4 Re: 3.4 is on!
    Becca Boo MizzBecca's Avatar
    Michigan
    Go big or go home ;p
    I drive a POS
  5. #5 Re: 3.4 is on!
    Donating Users
    Plainfield, IL
    Quote Originally Posted by MiZzBeCcA View Post
    lol well when it comes to kr* and pulleys if i go little my car might not make it home so i better be careful
  6. #6 Re: 3.4 is on!
    Michigan
    Quote Originally Posted by gotboost3 View Post
    lol agreed. go as big as you can
    I drive a POS
  7. #7 Re: 3.4 is on!
    anyone that knows what they are doing when they tune your car can tune all that out. my car knocked up to 10* before i started tuning it without the meth and we got it down to within 1*.
  8. #8 Re: 3.4 is on!
    Wausau, WI
    it doesnt say it in your sig.....but you got the U bend gone(assuming it is gone with the headers)
  9. #9 Re: 3.4 is on!
    GTP Level Member superv6's Avatar
    Apr 2009
    shawnee, kansas
    Wow dude. Our cars r almost identical in everyway now. They look the same, and now have almost the same mods. Silver/black gtp haulin ass! Yeah I wish I would have gone with the mps. And I need to scan my car to see where I'm at on kr. It feels good but I don't have anything to compare it to
    2003 GTP- 180 tstat,tb spacer,flipped dogbones,dhp pcm,3"catless dp,plog,thrasher fwi,3.4 pulley,msd 8.5mm wires,autolite 104s----------best run so far:14.1 @97mph
  10. #10 Re: 3.4 is on!
    ^^ Get Brian to HP Tune it...since we have '03's we could go half and half on the credits and it won't cost you over a hundred bucks.
  11. #11 Re: 3.4 is on!
    Aug 2008
    Long Island, New York
    you need a tune
  12. #12 Re: 3.4 is on!
    Apr 2009
    shawnee, kansas
    what you were plannin on gettin a tune done too?
  13. #13 Re: 3.4 is on!
    Quote Originally Posted by superv6 View Post
    I'm gonna need one with bigger injectors and my high flow SLP MAF
  14. #14 Re: 3.4 is on!
    Apr 2009
    shawnee, kansas
    right on. well, ive been wantin to get a tune for awhile. do you think at this point in my go fast stage is it even worth it to get a good tune? if so then im in bro. just let me know when you were thinkin
  15. #15 Re: 3.4 is on!
    yes. your car with higher timing and better fueling will be WAY stronger than it is now.
  16. #16 Re: 3.4 is on!
    Apr 2009
    shawnee, kansas
    sweet. so i guess my question is if you were at my stage in mods, where would you go next, considering im on a budget and i never really intend on doin any cam swap stuff, or bottom end stuff or anything like that.
  17. #17 Re: 3.4 is on!
    GT Level Member Swash's Avatar
    Excelsior Springs, MO
    When will people realize that getting your car tuned isn't just about performance gains??? IT WILL KEEP YOU FROM BLOWING IT UP!
    As little as 5* of knock can cause serious damage. Believe that.
    -Swash
    I'm sorry, I can't hear you over the sound of how awesome I am...
    2004 IBM/Black/A4 GTO -- 1 of 273 - and the slowest
    2002 Galaxy Silver GTP - a few mods - sold
  18. #18 Re: 3.4 is on!
    Donating Users
    Plainfield, IL
    gettin a tune on next weekend most likely from fast katt...i plugged the fpr vac line back on and i see alot or 3* on my aero and i peak and 5* haha ...threw a 180 stat in today so fastkatt can make my fans correspond with it...hopefull i can get down to 1* of knock at least....i think the gator back belt (came with it is slippping...gonna get a 3.5 tensioner to tighten it up )
  19. #19 Re: 3.4 is on!
    Apr 2009
    shawnee, kansas
    really? i thought the gatorbacks were supposed to provide more grip?
  20. #20 Re: 3.4 is on!
    Feb 2009
    They do. I have the incorrect belt on my setup, with the wrong size idlers which provide no tension and the damn thing has never slipped once.
