Thread: 3.4 is on! belt slip solved still knockin :)
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #21 Re: 3.4 is on!
    They do. I have the incorrect belt on my setup, with the wrong size idlers which provide no tension and the damn thing has never slipped once.
    That just means you don't have enough power
  2. #22 Re: 3.4 is on!
    Wausau, WI
    maybe his SC pulley looks like a riverboat paddle wheel..........no slippage there.......
  3. #23 Re: 3.4 is on!
    Donating Users
    Plainfield, IL
    lol i am an idiot....i have a 8 rib 3.4 and i had the belt off set toward the snout so only part of the belt was gripping! now i got a 3.5 oversized tensioner and lined the belt up correctly what a difference! and for some reason i lost a * of kr or it could be the 180stat i put it last night....i run the fans manually through my aero for now .....10 pounds of boost with no tune is respnosible for the rest !
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  4. #24 Re: 3.4 is on!
    Oct 2008
    Northern Illinois
    Quote Originally Posted by gotboost3 View Post
    gettin a tune on next weekend most likely from fast katt...i plugged the fpr vac line back on and i see alot or 3* on my aero and i peak and 5* haha ...threw a 180 stat in today so fastkatt can make my fans correspond with it...hopefull i can get down to 1* of knock at least....i think the gator back belt (came with it is slippping...gonna get a 3.5 tensioner to tighten it up )
    Is this guy local? I was just gunna order a custom tune from overkill but if there's someone local that does good custom tunes I'll do that.
  5. #25 Re: 3.4 is on! belt slip solved still knockin :)
    Donating Users
    Plainfield, IL
    hes in rockford, IL
  6. #26 Re: 3.4 is on! belt slip solved still knockin :)
    Oct 2008
    Northern Illinois
    hes in rockford, IL
    Really? Rockford isn't far from me at all.
    How much does he charge?
  7. #27 Re: 3.4 is on! belt slip solved still knockin :)
    Donating Users
    Plainfield, IL
    75 base tune (kinda like a canned tune but better), and for a full blown street tune (MAF, Fuel Trims) 25$ an hour.....he has some good rates
  8. #28 Re: 3.4 is on! belt slip solved still knockin :)
    Oct 2008
    Northern Illinois
    That's not bad at all, I'll probably have him tune my car after my topswap.
    Was just gunna order one from overkill but I assume this is better?
  9. #29 Re: 3.4 is on! belt slip solved still knockin :)
    $25/hr isnt bad at all. i know i spent a good four hours with my guy to get a BASE tune. my car still runs okay, but not up to its potential.
