Thread: power steering
Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
  1. #1 Re: power steering
    Bastard Reptile's Avatar
    Kansas City, MO
    Could also be leaking where the hose is crimped to the tube. Notorious on all of that type of line that GM runs on every one of their vehicles.
  2. #2 Re: power steering
    Oklahoma
    Are you willing to lay money on that?
  3. #3 Re: power steering
    Kansas City, MO
    Only if it's someone else's money!
  4. #4 Re: power steering
    GTP Level Member Toasty's Avatar
    SW Chicago Suburbs
    no, i stopped at the shop after they called me. it's spewing fluid from the return line fitting where it enters the rack. yet to be determined if the nut came loose, or worse than that.
    cost to replace the line w/ labor?? $400
    no, i cant replace the line on my own. no i havent been able to get any local assistance from the local boards (at least not that are close enough to get the car to them)
  5. #5 Re: power steering
    Oklahoma
    Man, I am truly sorry to hear that Toasty. Is that line that hard to replace? Im just asking I didnt imagine that line being that long of a run. Something just doesnt seem right with that quote. I would think that would include the cost of the rack as well.
  6. #6 Re: power steering
    Banned
    New Port Richey Florida
    WOW it cost me when i had mine done 40 dollars labor cause i bought the part.. Wow
  7. #7 Re: power steering
    Saraland Alabama
    how much is the line?
  8. #8 Re: power steering
    SW Chicago Suburbs
    it's 3 hours of labor to change it. --- have to disconnect the steering shaft, drop cradle, yada yada.
    previous place that did the work typically does good work, but i'm pretty sure they undercharged me on the labor when they did it. ---
    i didnt get the breakdown on the parts/labor, but i'd venture to guess that the line is under $50
    if i can get the crappy cell phone pic off my camera of the way the line is between the cat and sway bar, i'll post it
  9. #9 Re: power steering
    SW Chicago Suburbs
    its a tidbit blurry, but you'll get the idea
    power steering Attached Images
  10. #10 Re: power steering
    PA
    That is a very, very poor install. I would be going back to the place that did the rack install and trying to get them to do the work. I would be that the way they ran the line cause it to bend and crack. Or pull on the fitting to make it leak. To me, it is obviously a bad install job.
    2001 GSE
  11. #11 Re: power steering
    SW Chicago Suburbs
    Quote Originally Posted by Zef_66 View Post
    i agree, which is why i have the pic... unfortunately the situation that im in wont let me take the car back to them to fix... i do intend to go back there after the car is fixed, and at least see if they'll refund me what i paid them to fix it the first time.
  12. #12 Re: power steering
    PA
    Quote Originally Posted by Toasty View Post
    I highly doubt that if you go back there afterwards that they will refund your money. If you contact them ahead of time, shops will very often stand behind their work and fix the problem. But they won't let someone else do the work, then fork out the bucks for it.
    But I can understand everyone is in a different situation, and sometimes that drives the paths you can take. But if it were me, I would make every attempt to contact the garage that did the initial install and talk to them before anyone else does any work to the car.
    2001 GSE
  13. #13 Re: power steering
    Banned
    Yes the line runs any where from 20 to 50 dollars
  14. #14 Re: power steering
    Wichita, KS
    Thats a bad installment, and misrouting of the line for sure. Regardless if it leaked or not, it should NOT be there.
    I would call up the shop that did the work, and tell them that you did some work on ya-da-ya-da date and its leaking now. Can you help? They will say to bring it in, do that, they get it on the lift and will say what it is, and then go out with them, and have them show you. The make the comment, as to something along the lines as I don't think that line was to be ran that way, and clearly it got pinched or melted it causing it to leak.
    If they try to back out saying that our mechanics are ASE certified and know what they are doing, and if thats how it came out thats how it goes back in. Then say ok, and leave. Wait a day or two, then go back in, with a picture of the correct routing of the lines from one of us, and show them, a stock installment, and then use your car for reference.
    If its an honest shop they should repair the mess they made, part and labor for free, and clean up the mess as well. But if they are like any other dishonest shop, they will say we'll replace the part for free, but were going to have to charge you labor again. Thats why I work on my own cars...if I mess up, then its on me, but I normally don't because its not rocket science to work on cars.
    ~F~
  15. #15 Re: power steering
    SW Chicago Suburbs
    well, 400 dollars later, she's all fixed and ready to go. steers VERY smooth... somehow even seems better than before, which could just be my immagination.... ive talked to the place that originally installed the line, and the service manager said he's gonna do what he can to make it right. he agrees from what i described that it was a poor installation.
    so we'll see how it goes.
  16. #16 Re: power steering
    Wichita, KS
    They may have flushed the system. In which case, makes any old power steering system feel like new. If your fluid ain't clear, and YOU don't know the last time its been changed out, I suggest doing a flush. It will feel and drive like a whole new car again.
    ~F~
  17. #17 Re: power steering
    SW Chicago Suburbs
    Quote Originally Posted by GR8racingfool View Post
    ~F~
    LOL, with the ammount of fluid that went in, then out again with the massive leak, (leak was at the fitting for the return line at the rack, so everything that was put in, got pumped through the rack, then spewed out on the ground/car) i think i did the flush on my own
  1. Power Steering Pump Replacement [*]
    By UR LOSN in forum How To Write-Ups/Tech Tips
    Last Post: 05-11-2013, 03:28 PM
  2. Without power again
    By Rocket468 in forum Off Topic Discussion
    Last Post: 04-21-2011, 12:50 AM
  3. 2005 Power Steering Pump Seems Thrashed
    By Myoldmopar in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-12-2009, 07:28 PM
  4. Power Cut off
    By bburrows in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-02-2008, 05:07 PM
  5. Oklahoma guys with power :)
    By Rocket468 in forum Southwest
    Last Post: 12-28-2007, 01:42 AM
