Thread: A little Smoke on start up
Results 1 to 9 of 9
  1. #1 A little Smoke on start up
    SE Level Member 2k6GT's Avatar
    Troy
    I noticed the other day that my buddy took my car for a spin and i was following him to hear the difference with my dp and i noticed that it smoked out the exhaust on start up for about ten mintues and it's been doing it ever since. Any body know what could cause this???It's a 06 gt
  2. #2 Re: A little Smoke on start up
    el paso
    what color is the smoke?
  3. #3 Re: A little Smoke on start up
    Ohio
    It is probably just condensation in the exhaust. I wouldnt worry about it unless it doesn't stop smoking.
  4. #4 Re: A little Smoke on start up
    Troy
    The smoke is white and really looks like steam on a cold morning.. but it was 85 derees out so it wasn't cold....
  5. #5 Re: A little Smoke on start up
    GT Level Member skidoojames151's Avatar
    seattle
    uhh, how many miles? and do you have a cam and head work done...could be bad seating of the valves...or it could be a head gasket which is why i asked if head work was done which would mean the head was removed
  6. #6 Re: A little Smoke on start up
    Wausau, WI
    head gasket bad=white smoke=bad.........check your coolant level.......is it the right color and is it full?
  7. #7 Re: A little Smoke on start up
    Troy
    I't's a 06 80k and a couple of bolts on parts nothing major... but it is a special edition and the dual mufflers do not have holes in them for water to drain so i'm thinking it may be the condinsation like blown said but i'm not sure.. And the coolant level is fine but i'm still running dex-cool
  8. #8 Re: A little Smoke on start up
    Wausau, WI
    Quote Originally Posted by 2k6GT View Post
    I wouldnt worry about it then.......if it is only at start up until the engine is warm then dont worry about it. If it does it all the time, you may need to look into this further........fwiw
  9. #9 Re: A little Smoke on start up
    Charles City, IA
    Smell it and see what it smells like.
    SMGPFC Two Nipple General
  1. Tried Seafoam on my car with no smoke? did i do it right?
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-03-2010, 11:51 PM
  2. smoke coming through the a/c vents
    By bonerjamz03 in forum General Tech Discussion
    Last Post: 08-19-2009, 07:05 PM
  3. interior Smoke Smell
    By 99SactownGT in forum General Tech Discussion
    Last Post: 08-02-2009, 12:26 AM
  4. smoke out tail lights
    By mzendano in forum Visual/Body Modifications
    Last Post: 04-01-2009, 11:58 AM
  5. 3.8 series II sc blows smoke with rev
    By GTX in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-16-2008, 01:09 PM
