Thread: Tried Seafoam on my car with no smoke? did i do it right?
Results 1 to 20 of 23
  1. #1 Tried Seafoam on my car with no smoke? did i do it right?
    SE Level Member azmattaz06's Avatar
    Feb 2009
    Tucson
    So i added about a 3rd of seafoam into the break booster vaccum with the car running and shut it off and left it in for about 20 minutes and my car started right away and only a little bit of smoke came out but it stopped quick and then it was spitting liquid out of the exhaust not much but some was coming out.. anyone know whats up? is my car really that clean? lol let me know what you think thanks..
  2. #2 Re: Tried Seafoam on my car with no smoke? did i do it right?
    I live here. UR LOSN's Avatar
    Rockford, IL
    The liquid coming out of the exhaust pipes...is just plain old water. Its just the catalytic converter....doing its job
    I would put Seafoam into the gas tank to help clean out the injectors...
  3. #3 Re: Tried Seafoam on my car with no smoke? did i do it right?
    Quote Originally Posted by UR LOSN View Post
    THAT...is where you'll get the smoke lol
  4. #4 Re: Tried Seafoam on my car with no smoke? did i do it right?
    Aug 2008
    Long Island, New York
    what is seafoam??
  5. #5 Re: Tried Seafoam on my car with no smoke? did i do it right?
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    Nope, you get the smoke by putting SeaFoam in the intake or a vacuum line. If your engine is clean, you may not see much...it is when there is built-up carbon that it makes the smoke show.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  6. #6 Re: Tried Seafoam on my car with no smoke? did i do it right?
    Dec 2008
    Canada
    Quote Originally Posted by JoshMcMadMac View Post
    Ehh this can be debated, some people say the carbon makes the smoke. I whole-heartedly disagree, seafoam is an oilbased product the smoke comes from the oil You should be seeing smoke no matter what.
  7. #7 Re: Tried Seafoam on my car with no smoke? did i do it right?
    Waynesboro, PA
    Quote Originally Posted by 1998xGTP View Post
    It can be debated, but I have run it on cars for the first time and made enough smoke to engulf a two-story house. Doing the same thing one year later, the smoke was very minimal. I fail to see any other contribution to the smoke other than build-up in the engine. I have never seen smoke made when adding half of a can to an almost empty tank of gas, or adding it to the oil just before a change.
    I also know a guy that gets similar results using water.
  8. #8 Re: Tried Seafoam on my car with no smoke? did i do it right?
    Dec 2008
    Canada
    I always seafoam, we seafoamed our Jeep last year when we bought it brand new and still got the smoke show. Not once when I have used it, did it let me down in that aspect, that being said I also believe that the carbon build up plays a part in it and you will more then likely get more smoke with more build up. Now that brings me to the second part, some people also say using seafoam can hurt your engine as it breaks off large parts of carbon instead of breaking it down into much smaller pieces (I disagree because I have never seen huge chunks coming out of the exhaust).
  9. #9 Re: Tried Seafoam on my car with no smoke? did i do it right?
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    Well driving habits also play a big role in the amount of carbon buildup present. If you drive your car hard often you'll more than likely not have that much carbon buildup compared to a car that rarely ever gets driven hard. My car barely smoked at all when I seafoamed it for the first time at 140K, but that makes sense since I regularly beat on it .
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  10. #10 Re: Tried Seafoam on my car with no smoke? did i do it right?
    Aug 2008
    KCMO
    what is this seafoam?
  11. #11 Re: Tried Seafoam on my car with no smoke? did i do it right?
    Barksdale AFB, LA
    Quote Originally Posted by carl06GT View Post
    seafoam - Google Search
    2009 Subaru Impreza WRX STI
  12. #12 Re: Tried Seafoam on my car with no smoke? did i do it right?
    Donating Users RedLedbetter's Avatar
    Feb 2009
    Illinois
    is the brake booster the best place to get the seafoam sucked up?
    SPREAD THE JAM
  13. #13 Re: Tried Seafoam on my car with no smoke? did i do it right?
    Dec 2008
    Canada
    Quote Originally Posted by redprix View Post
    Depends on what you want done, when I do it I put 1/3 in the vac line 1/3 in BB and then the rest in the tank wait 20-25 mins and then just drive her into the dirt.
  14. #14 Re: Tried Seafoam on my car with no smoke? did i do it right?
    Nov 2008
    Searcy,Arkansas
    Done that to every car/truck I ever owned! Had the 07 for about 2 months and did it..didnt get much smoke but it did a little. My moms old ford...OMG! LOL I thought it was on fire it smoked so bad. But it ran better then when she first got it! If your going to use Seafoam do it the right way...go threw the vacuum line!
  15. #15 Re: Tried Seafoam on my car with no smoke? did i do it right?
    SE Level Member Alucarus99gt's Avatar
    St.Paul, MN
    Actually thats kind of funny because mine did the same thing. But what I'm thinking is, is that I did it when my engine was cold and I hardly had ne thing come out. When my friend did his though he was at operating temp. Now that I think about it that actually kind of makes sense because the whole point is that you're trying to get the seafoam to soak into the deposits and then burn off. When it's cold its not going to do what its supposed to. Atleast thats my theory, which i'm going to test out tomorrow. It makes sense though, cuz pretty much anything you want clean usually involves heat like washing carpets, dishes, or clothes. The heat expands the molecules loosing them up. Anyway! My point is that I KNOW my engine isn't that clean, cuz when I cleaned my throttle body you can totally see the ridiculous amount of gunk that was built up, especially in the UIM. Imma seafoam my car again tomorrow at op temp and let you know what happens, but I'm pretty sure I'm right.
  16. #16 Re: Tried Seafoam on my car with no smoke? did i do it right?
    Apr 2009
    stockton ca
    Every car i have seafoemed has smoked When the cars were older and had been run hard the smoke was darker and on cleaner newer engines like my fresh build it still smoked but was more white
    it also depends on if the engines hot when you do it and so on
    With the gtp it doesnt die with the seafoam but the truck and my crown vic do
  17. #17 Re: Tried Seafoam on my car with no smoke? did i do it right?
    Donating Users Warbeaver's Avatar
    St. Louis
    smoked like hell first time i did it, year and a half later it smoked all of one minute and that was it.
    o, and 1998xGTP, i LOL'd at your sig here at work for the longest time. that is truly awsome
  18. #18 Re: Tried Seafoam on my car with no smoke? did i do it right?
    Donating Users ls6velless454's Avatar
    Nov 2009
    Portage, IN
    I seafoamed my 2000 with 115k I'm pretty sure it was never done before because it smoked like a freight train. I did my honda as well and it smoked like hell too. 2/3 in the vac and the rest in the tank. H
    There is no replacement for displacement........unless you have a supercharger or turbo
    2000 Bright Red GTP Coupe GXP axle back, GMPP sway bar, NGK TR6, 180 stat. (Uninstalled Aeroforce Interceptor, DHP PCM, FWI, Gen V on the way) and still no pulley in sight.
  19. #19 Re: Tried Seafoam on my car with no smoke? did i do it right?
    Dec 2008
    Canada
    I miss the days when I cared enough to make legit posts
    Quote Originally Posted by Warbeaver View Post
    Thanks man I thought it was funny too haha, stupid troll girl haha
  20. #20 Re: Tried Seafoam on my car with no smoke? did i do it right?
    Donating Users lflylow's Avatar
    Yakima, WA
    seafoamed My T/A with 120k it smoked like crazy 1/2 in the BB 1/2 in the oil and a can in the tank
    2000 GTP, retro's, Debadged, 15% Tint, SD headers, TB HAI, EGR delete,
    Tuned By Reptile, WBS Perf. LCA's, GMPP rear sway bar Dorman front, Tinted tails.
  1. intakes/exhaust/seafoam
    By FtBll Coach in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-08-2009, 10:04 PM
  2. smoke light covers
    By mzendano in forum Visual/Body Modifications
    Last Post: 12-09-2008, 01:28 PM
  3. Throttle Body Seafoam????
    By kappy332 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-25-2008, 12:42 PM
  4. Seafoam
    By J_Man55 in forum General Tech Discussion
    Last Post: 08-08-2008, 08:23 PM
  5. Seafoam Trans Tune any good?
    By 99BluGP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-28-2008, 09:01 AM
