Thread: Wiring issue...
Results 1 to 8 of 8
  1. #1 Wiring issue...
    Moore, Oklahoma
    I'm no wiring expert but...
    Lately i've noticed my harness between the fans, the wires are getting hotter than hell. Hot enough to cause the plug connector to start melting, on the side with the black wire. What would cause this to happen all of a sudden? I donno what to check or how to check this but I know I need to figure this out. I;'ve never had a wiring problem with the car until now.
    And no, the wires aren't getting hot from the engine bay or the headers, its in the wiring itself.
    Anyone have any input?
    Shawn W. Larsen
  2. #2 Re: Wiring issue...
    Moore, Oklahoma
    TTT
    Shawn W. Larsen
  3. #3 Re: Wiring issue...
    Houston, TX for now
    I don't have any specific ideas, but a wire gets hot when there is more current flowing through it then the structure of the wire can handle. So if it a wire going to a fan motor, more then likely the motor is on it's way out and it is pulling more flow than it should. Godd luck
    2000 GRAND PRIX GTP COUPE WITH THE NORMAL LIST MODS TO MAKE IT LOUDER, FASTER AND OF COURSE SEXIER!! 267 WHP @ 9000 FT ABOVE SEA LEVEL
  4. #4 Re: Wiring issue...
    Moore, Oklahoma
    I think its comming from the harness side though. Is there anyway I can test this? I have a multimeter, just very little know how on using it.
    Shawn W. Larsen
  5. #5 Re: Wiring issue...
    Houston, TX for now
    Quote Originally Posted by Iron Indian View Post
    I'll ask the guys at work tomorrow and report back. Have you had any luck yet?
  6. #6 Re: Wiring issue...
    Moore, Oklahoma
    Quote Originally Posted by LOUDANDPROUDGTP View Post
    Nope
    All I can do is splice in a new conector, fill it with diectric grease and see what it does i guess
    Shawn W. Larsen
  7. #7 Re: Wiring issue...
    GT Level Member Gregorius's Avatar
    Davenport, IA
    I'd call it a corroded connection on the fan. About all it could be. Pull it apart, scrape it and grease it. Maybe water in a relay.
    Dude! Full Service Manuals! 2004-'08 User manuals, full docs wiring diagrams trouble codes... go look.
    WarStryker13's Google drive
    ... our lady of blessed exceleration, don't fail me now ...
  8. #8 Re: Wiring issue...
    Banned - Busted For Scamming
    Feb 2009
    Could just be a bad connector design, faulty wiring, etc. Its really hard to tell, but if it was a short to ground it would have probably tripped the breaker.
  1. sub wiring
    By grand2000prixgtp in forum Audio, Security & Visual Electronics
    Last Post: 09-20-2009, 02:37 AM
  2. Door Wiring Issue
    By Feather Head in forum Audio, Security & Visual Electronics
    Last Post: 08-21-2009, 09:38 AM
  3. Need help wiring amp
    By jjwitty in forum Introductions/Noob Questions
    Last Post: 07-24-2009, 01:59 PM
  4. Amp Wiring
    By jjwitty in forum General Tech Discussion
    Last Post: 07-23-2009, 09:21 PM
  5. Wiring
    By gpgt in forum Audio, Security & Visual Electronics
    Last Post: 03-27-2009, 03:02 PM
