Thread: projector headlight question
Results 1 to 3 of 3
  1. #1 projector headlight question
    GTP Level Member superv6's Avatar
    Apr 2009
    shawnee, kansas
    lets see, ive decided to get a set of projectors for my gtp. i know what they look like and love the way they look. how easy are they to install and wire up? ive read a bunch on them. ive noticed that the mounting brackets are flimsy and can break easily, but thats no big deal. i know i can fix the "bounce" problem easily enough. ive also read that they are kinda hard to adjust, but oh well. what all comes with the lights? does it come with instructions for wiring it up? does it come with bulbs? if not, which ones should i get for them. i can figure out how to wire them up i suppose, and ill want them to work just like the stock ones, like blinking when i hit the unlock and lock buttons, and turn signal and bright and low beams and everything. maybe ill just end up gettin them and then readin up online about it. any comments im sure would help.
    2003 GTP- 180 tstat,tb spacer,flipped dogbones,dhp pcm,3"catless dp,plog,thrasher fwi,3.4 pulley,msd 8.5mm wires,autolite 104s----------best run so far:14.1 @97mph
  2. #2 Re: projector headlight question
    Donating Users
    Plainfield, IL
    easy to install and wire up...red on halos to brown on big signal bulb wire, black on halos to black on big signal bulb...(this will keep the halos from flashing with your blinkers) if you wire it to the smaller signal bulb they will flash....easy to aim just end of leaving a lil gap on the insides if it ends up uneven loosen the bolts on the top of the bumper and slide the top of the bumper around to even it out....other than that just do the club gp no bounce mod and i shaved down the cutoff with great results....they only come with the H1 low beams you will have to buy the 9005 hi beams and no they dont come with instructions...that about sums it up
    NO LONGER USING THIS NAME MY NEW USER IS BOOSTJUNKI3!!!!
  3. #3 Re: projector headlight question
    Apr 2009
    shawnee, kansas
    Wow thanks bro. That really helps a lot man
  1. I need projector help
    By rocafella2032 in forum Visual/Body Modifications
    Last Post: 04-30-2011, 07:47 AM
  2. headlight question
    By NewPrixOwner666 in forum Visual/Body Modifications
    Last Post: 06-16-2009, 10:02 PM
  3. New Member with projector headlight question
    By tdaye in forum Introductions/Noob Questions
    Last Post: 06-10-2009, 12:08 AM
