Yup...sounds like a toasted IAC...you can try cleaning it but I would just get a new one...also check the black rubber "T" fittings around the LIM and under the blower snout...they tend to rot out and cause crazy things to happen![]()
I cleaned my IAC tonight. Need to do the test run tomorrow. It only happens sometimes when the car is warmed up. My IAC didn't have an o-ring. Should it? If its supposed to have one then I am guessing that when its warmed up a vacuum leak occurs around the IAC, hence the fast idle.
It ended up being a vacuum leak on the intake manifold vacuum line tee. The one under the supercharger pully. I fixed it and the problem went away.
I fixed another problem too where the car would start up, then stall right away. It was a bad IAC.
