Thread: Fuel Pressure Gauge
Results 1 to 17 of 17
  1. #1 Fuel Pressure Gauge
    Wichita
    The fuel pressure gauge on my fuel logs seems to have mysteriously stopped working. The needle never moves. I have no idea what my fuel pressure is at now.
  2. #2 Re: Fuel Pressure Gauge
  3. #3 Re: Fuel Pressure Gauge
    Wichita
    It does kinda suck cuz they were expensive. Lucky me the new motor came with a fuel rail.
  4. #4 Re: Fuel Pressure Gauge
    Wausau, WI
    cool.
    LOL @ bio
    And get a new gauge...
  5. #5 Re: Fuel Pressure Gauge
    Wichita
    Quote Originally Posted by Liquifire View Post
    LOL @ bio
    I'll see what I can do
  6. #6 Re: Fuel Pressure Gauge
    Wausau, WI
    should be covered by warranty if they are fairly new...
  7. #7 Re: Fuel Pressure Gauge
    well, he didnt ask a question or anything. what was i supposed to say?
  8. #8 Re: Fuel Pressure Gauge
    Wausau, WI
    I know what you mean.......I just would not have expected you to say anything other than what you did.
  9. #9 Re: Fuel Pressure Gauge
    Wichita
    dot dot dot I should've asked what I should do. If I can send it back to ZZP or contact Fuelab to see if either of them would cover it or replace it. Haven't had the Fuellogs six months yet =\
  10. #10 Re: Fuel Pressure Gauge
  11. #11 Re: Fuel Pressure Gauge
    Wausau, WI
    call zzp, if they are no help or wont take them back then contact fuelab and see if they will help you out.
  12. #12 Re: Fuel Pressure Gauge
    Wichita
    Just sent an email to ZZP. Hopefully they or Fuelab will replace the gauge
  13. #13 Re: Fuel Pressure Gauge
    Wichita
    Switched out the ZZP Fuel Logs as they were causing knock. ZZP hasn't responded yet-It's been 6 days.
  14. #14 Re: Fuel Pressure Gauge
  15. #15 Re: Fuel Pressure Gauge
    Wichita
    Yeah, probably so. I did get an email from ZZP this morning stating that their Fuel Logs are covered under warranty. They will replace the entire item.
  16. #16 Re: Fuel Pressure Gauge
    How was the log causing knock?
  17. #17 Re: Fuel Pressure Gauge
    Wichita
    It wasn't the logs per-say but the bad fuel pressure gauge. Car was running lean enough to get 23mpg no matter how I drove it. It drove like sh*t & the Boost bars would flicker like crazy.
  1. Oil Pressure Gauge...
    By mickey t in forum General Tech Discussion
    Last Post: 08-31-2009, 10:56 PM
  2. fuel pressure gauge
    By gtchris in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2009, 02:43 PM
  3. how to use a fuel pressure gauge?
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2008, 01:06 PM
  4. Fuel pressure and fuel in the rails
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:03 AM
  5. anyone have a Prosport fuel pressure gauge?
    By fst in forum PCM Tuning
    Last Post: 04-02-2008, 06:38 AM
