It's called a "seat belt retractor". Different part numbers for different years and different part numbers for coupes and sedans. New they are $75-100 each. Check out Ed Moradname of the part
Morad Parts Company - 3800 Motors, Transaxles, & Stock Parts for an economical replacement if you don't want to hit a local salvage yard.
No. Console and the Trim Plate Assembly are two seperate parts. Console is the same for all years (97-2002), Trim Plate shows three part numbers (97-99, 2000-01, 2002). Console is $75.50, Trim Plates are $98. Once again Ed Morad can probably fix you up MUCH cheaper. He's saved me hundreds.will it come with that panel? If not, where can I get a new one?
Note: My prices are from 2003 so they are almost certainly low.
The button on the shift knob changes the shift points of the transmission. It will hold in a gear longer when the button when you're in performance mode then when you're not.anyway to know the car is going into performance mode.
