Thread: Attempting '97 Dual Climate Control Swap- Building shopping list
Results 1 to 3 of 3
  1. #1 Attempting '97 Dual Climate Control Swap- Building shopping list
    Jan 2009
    MN
    I think I'm gonna go for it, despite the fact that it may be not worth it/really tough. I'm just really curious, and think it could be a fun project. I'm heading to the junkyard, and wondering what all I need to buy to complete it. Studying the wiring diagrams, I believe I need:
    -Sun Sensor
    -Interior/Exterior Temp Sensors
    -Control Display (obviously)
    -Control module/black box it connects to
    -Blower motor control module
    -Vacuum distributor/solenoid thing
    -electric temp actuators, driver and passenger side
    -as much wiring and vacuum lines as I can grab
    What else is different between the two systems? Are the vacuum-controlled vent actuators different? I've heard the blower motor is different, but it appears to be the same according to the wiring diagram. Someone had mentioned something about a different evaporator core as well.
    I understand this project is probably not worthwhile, but I'm like to give it a shot anyway. I figure if we all compile what we know then it won't be a total shot in the dark. Thanks a lot.
  2. #2 Re: Attempting '97 Dual Climate Control Swap- Building shopping list
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    If yours is the same as the '99, then I'm interested in this too. I have a 2001 model that is soon to be scrapped and the climate control is something I have my eye on because I don't like the one in ours. It sounds as if it's pretty involved. I was hoping for a plug and play, but didn't think it was likely.
  3. #3 Re: Attempting '97 Dual Climate Control Swap- Building shopping list
    New Brunswick
    I just finished this myself but it is in an 04 model which is completely different, have yet to gather and post a writeup,
    for mine i needed the temperature control valve/flap(the double one not single) the climate control, wiring, 4 temp sensors, cabin temp sensor,extra temp actuator, and the sunload sensor.
    Everything else remained the same.
    it is a nice project and if you know aout electrical and things like that it shouldnt be too hard. I can browse through alldata and see what i can find for you
  1. 98 GTP dual climate control-metric?
    By Liquifire in forum General Tech Discussion
    Last Post: 07-26-2009, 03:41 PM
  2. Swapping Single Climate control to a dual climate control
    By mkuhn20 in forum General Tech Discussion
    Last Post: 02-17-2009, 03:35 PM
  3. will 05 dual climate control fit in an 04 gt2?
    By gp04duff in forum General Tech Discussion
    Last Post: 12-01-2008, 07:08 AM
  4. Dual climate control
    By 04gpking85 in forum General Tech Discussion
    Last Post: 10-12-2008, 11:41 PM
  5. Dual zone climate control
    By CT Tech in forum General Tech Discussion
    Last Post: 07-10-2008, 02:05 PM
