Thread: 98 GTP making noise by supercharger?
Results 1 to 9 of 9
  1. #1 98 GTP making noise by supercharger?
    SE Level Member hunter_alexander's Avatar
    Erie Pa.
    OK, Havent been here in a while. I have a noise coming from what seems like the supercharger.
    Now having read about the snout coupler, I am thinking that it may be the culprit.
    I have also read reports about the flywheel being two piece and developing cracks in it, which makes it rattle and possibly sound like its coming from the motor. (but I doubt thats it).
    I have listened real carefully to the supercharger snout, and it seems like it is definitely coming from there.
    It sounds like the sc is grinding up rocks.
    Now, I also have seen on here a gent selling the snout rebuild kits, and the coupler by rolling performance.
    Mainly, I am looking for verification that the sc is probably the issue, and would love some feedback on rolling performance before I drop the cash.
    Thanks all.
    If all else fails, throw money at it..... that'll fix it.
    Check out my website here: http://craig.beesky.com/1987_olds_cutlass.htm
  2. #2 Re: 98 GTP making noise by supercharger?
    CT
    If your describing rocks tumbling in the super charger then you are correct.
  3. #3 Re: 98 GTP making noise by supercharger?
    Nov 2008
    Searcy,Arkansas
    Coupler if it sounds like grinding rocks.
    If it sounds like this...here ya go...pretty good video..not sure if anyone on here made this but it helped me!
    http://www.youtube.com/watch?v=pSsSctYvOoI
  4. #4 Re: 98 GTP making noise by supercharger?
    Donating Users mystic231's Avatar
    Michigan
    I had noise in the area of the supercharger so I ordered a new coupler up. Waterpump went bad, changed it, noise gone. It took about a week and a half from when I first noticed the noise to having the pump shaft seize and shread the water pump.
    '98 Bright Red GT 278,000 miles and counting...
    '02 Galaxy Silver GTP GMPP Suspension, F Body front brakes, TDC FWI intake, Ported M90, Intake, and Throttlebody, Overkill PCM
    '02 Bright Red GT
  5. #5 Re: 98 GTP making noise by supercharger?
    Erie Pa.
    Thanks everyone.
    Now the next question. Should I do the whole snout rebuild or should I just replace the coupler? Car is very well taken care of, has 134K on the clock though.
    How long do the bearings last?
    I know that since I will have the snout off anyways that it would be a good time to replace them, just looking for some words of wisdom.
    Thanks again
    Craig
  6. #6 Re: 98 GTP making noise by supercharger?
    Nov 2008
    Searcy,Arkansas
    Quote Originally Posted by hunter_alexander View Post
    Thanks everyone.
    Thanks again
    Craig
    I was told by many of the guys on here that the coupler usally goes bad because its not very durable. I wouldn't think you would need to do a snout rebuild..My car is a 07 and I replaced mine with like 45K miles on it. You should be fine but I would for sure ask Bluegtp91 or Bio and there is alot more people who could give you advice too!
  7. #7 Re: 98 GTP making noise by supercharger?
    belle vernon pa
    your coupler is definitely bad. how many miles are on the supercharger?
  8. #8 Re: 98 GTP making noise by supercharger?
    Just replace the coupler...get one of those bitc*in green ones from ZZPerformance and new GM Oil...then you're good to go.
  9. #9 Re: 98 GTP making noise by supercharger?
    Charles City, IA
    SMGPFC Two Nipple General
  1. Pulley making metal grinding noise??
    By abuckley1290 in forum General Tech Discussion
    Last Post: 07-14-2010, 10:46 PM
  2. Supercharger Noise
    By Clar2478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2009, 03:45 PM
  3. UPDATE on trans flush making noise!
    By mikedinthecity in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-30-2009, 01:53 AM
  4. Engine making horrible noise.
    By starscr33m in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2009, 12:24 AM
  5. Brakes making noise.
    By TDCRacing in forum Brakes/Suspension/Chassis
    Last Post: 07-26-2008, 10:03 AM
