Thread: power stearing pulley??
Results 1 to 8 of 8
blowfishRus6 power stearing pulley?? 07-26-2009, 08:20 PM
Liquifire Re: power stearing pulley?? 07-26-2009, 09:03 PM
blowfishRus6 Re: power stearing pulley?? 07-26-2009, 10:26 PM
blowfishRus6 Re: power stearing pulley?? 07-27-2009, 11:58 AM
mystic231 Re: power stearing pulley?? 07-27-2009, 04:01 PM
blowfishRus6 Re: power stearing pulley?? 07-28-2009, 12:42 AM
Guest Re: power stearing pulley?? 07-28-2009, 12:49 AM
blowfishRus6 Re: power stearing pulley?? 07-28-2009, 11:30 AM
  1. #1 power stearing pulley??
    Donating Users blowfishRus6's Avatar
    g.a.
    im trying to remove the water pump and the power stearing pulley is in the way of the last bolt. i dont think i can take the power stearing unit off itself with out taking the pulley off to get to some of the bolts. i cant quite tell if its a hex screw in the pulley or its just maybe pressed on, i dont know. does anybody have any info on it??
    o yea and haynes manuals blow.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  2. #2 Re: power stearing pulley??
    Wausau, WI
    sorry I can't help as I don't know, but I would like to second the notion that haynes manuals blow.........
  3. #3 Re: power stearing pulley??
    g.a.
    anyone??
    its slow.
  4. #4 Re: power stearing pulley??
    g.a.
    its slow.
  5. #5 Re: power stearing pulley??
    Donating Users mystic231's Avatar
    Michigan
    Just changed my water pump last week.
    Leave the pulley on the pump. Instead pull the pump off the engine and lay it against the firewall enough to get access to the final bolt. The power steering pump is held on with two 13mm bolts that you access through holes in the power steering pump pulley.
    If you should ever have to change the power steering pump you DO need to remove the pulley and there is a dedicated puller for that. In order to do it (remove the pulley) the service manual says you have to pull the pump first.
    '98 Bright Red GT 278,000 miles and counting...
    '02 Galaxy Silver GTP GMPP Suspension, F Body front brakes, TDC FWI intake, Ported M90, Intake, and Throttlebody, Overkill PCM
    '02 Bright Red GT
  6. #6 Re: power stearing pulley??
    g.a.
    sweet. ill give it a shot tm but im pretty sure that shoud work.
    thanks. now i just gotta get to a hardware store and get some more bolts that someone left out before when they did it...
    its slow.
  7. #7 Re: power stearing pulley??
    TDCRacing
    Guest
    Sorry I'm late but he covered it. Let us know if you have any more issues there fruit loop
  8. #8 Re: power stearing pulley??
    g.a.
    yea that did the trick, man i feel like an idiot.
    now to wait on a ride to the hardware store :/ damn i need a second car.
    its slow.
  1. To Pulley or not to Pulley is not the question.... SIZE IS
    By massivesystem in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2009, 10:43 AM
  2. power steering pulley tool
    By cuda010 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-14-2009, 07:11 PM
