Just changed my water pump last week.
Leave the pulley on the pump. Instead pull the pump off the engine and lay it against the firewall enough to get access to the final bolt. The power steering pump is held on with two 13mm bolts that you access through holes in the power steering pump pulley.
If you should ever have to change the power steering pump you DO need to remove the pulley and there is a dedicated puller for that. In order to do it (remove the pulley) the service manual says you have to pull the pump first.
