Thread: what size tires?
Results 1 to 19 of 19
  1. #1 Re: what size tires?
    SE Level Member sUpErClEaNbLaCkMaChInE's Avatar
    STOCKTON, CA
    245/45/17...worked for me.
    How does the sidewalls look with the wider tire?
    Can I go with a higher sidewall? Like, 5mm higher
    2007 GP GT 3.8 S/C.180 Tstat. 605 ALs. Drop in K&N. 45K HIDS.
    1984 CHEVY C-10
    1986 OLDS CUTLASS SUPREME
  2. #2 Re: what size tires?
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    Quote Originally Posted by sUpErClEaNbLaCkMaChInE View Post
    Not if you're trying to keep the cost down. 245/45R17 is a fairly common tire. If you want to go taller to stay with the same diameter as OEM, you're going to pay through the nose to fit a 17" rim.
  3. #3 Re: what size tires?
    STOCKTON, CA
    Quote Originally Posted by SnowDrift View Post
    so basically stick with the OEM suggested tire or go with the 245 44 17s. Thanks man i guess im stuck paying regardless.
    1984 CHEVY C-10
  1. What size pulley and what size belt??
    By David99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2009, 08:55 AM
  2. stock size? PLEASE HELP on piping and 2.25 muffler size
    Last Post: 07-27-2008, 09:52 PM
  3. is it ok to mix tire size?
    By nemesis in forum Tires & Wheels
    Last Post: 07-20-2008, 12:36 AM
  4. Max Size Tires?
    By N3p in forum Tires & Wheels
    Last Post: 04-30-2008, 12:54 AM
  5. what size rim
    By blazedgp in forum Tires & Wheels
    Last Post: 02-20-2008, 01:49 PM
