Thread: issues with JP double roller crank gear removal
Results 1 to 5 of 5
  1. #1 issues with JP double roller crank gear removal
    May 2008
    ok so as some know my trans took a **** a while back and had to be rebuilt. I did that at school along with a XP cam and powerbond balancer. well long story short the balancer spun while i was putting it on and sheered the key on the crank so off with the front cover and double roller and that damn bottom gear will not come off. any suggestions? i would really like to avoid using a prybar and have had issues with getting a puller on the back.
  2. #2 Re: issues with JP double roller crank gear removal
    use a pry bar.
    or if you have one, use a pulley/gear puller.
  3. #3 Re: issues with JP double roller crank gear removal
    Same here...had the issue. Little pry gives you room for a puller if it needs that much.
  4. #4 Re: issues with JP double roller crank gear removal
    May 2008
    yeah the key is making it that much harder.
  5. #5 Re: issues with JP double roller crank gear removal
    May 2008
    just thought id let you guys know slide hammer FTW.
  1. Machining double roller crank gears (pics + vid)
    By GR8racingfool in forum How To Write-Ups/Tech Tips
    Last Post: 07-27-2009, 08:18 AM
  2. JP Double Roller Timing Sets
    By japslpr in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-27-2009, 04:10 PM
  3. which double roller
    By QwikGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-05-2008, 06:52 PM
  4. Timing a double roller?
    By Andrew_99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-03-2008, 06:57 PM
  5. Double roller issues
    Last Post: 05-03-2008, 09:07 AM
