Thread: HUD turned metric!
Results 1 to 7 of 7
  1. #1 HUD turned metric!
    philly
    I replaced my heater core last weekend, and when I had everything put back together, my HUD had turned metric and my Trip Computer doesn't light up. Fuses all look good. I don't know what it could be. Any ideas?
    edit - 1998 Grand Prix GTP
  2. #2 Re: HUD turned metric!
    Banned - Busted For Scamming
    Feb 2009
    On the dic, it will allow you to switch to metric, it also controls the hud. Its labeled eng/met if im not mistaken
  3. #3 Re: HUD turned metric!
    philly
    You know what, I'm stupid and I knew that. I was freaking out cause I thought I had unplugged something and would have to take the whole interior apart again. Thanks
    Well that fixes the metric issue, but the DIC light is still out. Maybe it's just a dead bulb? Think I just got unlucky and it all happened at the same time?
  4. #4 Re: HUD turned metric!
    Feb 2009
    The dic is gonna be a bulb. There are like 3 bulbs that backlight the display, you can either replace them with normal incandescent, or go the led route, which would be better, brighter.
  5. #5 Re: HUD turned metric!
    Wausau, WI
    when you go the LED route does it still dim with the lights or is it on full strength at all times?
  6. #6 Re: HUD turned metric!
    Feb 2009
    Im not sure, i know its brighter. I have not actually done this myself yet although there are plenty of members on here who have and could probably answer that question.
  7. #7 Re: HUD turned metric!
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    it should dim as well. when I replaced my interior lights with LED's, when the lights start dimming out, so does my new LED's just like the stock bulbs but insted of dimming to a finish, it'll dim alil then just go out. so Yes I would think so.
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  1. just turned 18! sick!
    By 2000GTP in forum Off Topic Discussion
    Last Post: 06-30-2009, 08:04 PM
  2. Best place to get metric bolts?
    By 99prixgt in forum General Tech Discussion
    Last Post: 03-29-2009, 08:20 PM
  3. Air condition/vents smell when turned on! How do I fix?
    By Freebeer187 in forum General Tech Discussion
    Last Post: 08-08-2008, 12:54 PM
