Thread: Oil filters
Results 1 to 20 of 23
  1. #1 Oil filters
    Charles City, IA
    After reading the oil filters dissected thread. I am curious to see what every one runs? I have been using K&N ever seen I bought my car.
    SMGPFC Two Nipple General
  2. #2 Re: Oil filters
    Jul 2008
    sumter,south carolina
    K&N since i have owned my car... and ill probably keep using them.However the mobil 1 is virtually the same as k&n for 2 bucks cheaper.
    02 GTP with mods 05 GP for DD
  3. #3 Re: Oil filters
    Charles City, IA
    They are the same except for the 1" nut on the K&N. I like the option of the nut just in case i over tighten the filter and can not get it off.
  4. #4 Re: Oil filters
    Moore, Oklahoma
    I run AC/Delco on all my vehicles.......
    Shawn W. Larsen
  5. #5 Re: Oil filters
    Banned - Busted For Scamming
    Feb 2009
    fram, cheap. what does it matter? if you change it every 3k like you should filter size being a tad smaller doesnt really matter, never had a problem with them clogging, and honestly, if you have that many contaminates in your oil there is a problem anyways.
  6. #6 Re: Oil filters
    Moore, Oklahoma
    I run stock sized PF 47 on my GPs, no 52s... Oddly enough, my TBSS takes a PF48...
    Shawn W. Larsen
  7. #7 Re: Oil filters
    GTP Level Member Scimmia's Avatar
    QCA, IA
    I generally run a Wix/Napa Gold filter, great filters for the money. I've been using Mobil1 lately because of oil change deals at Autozone.
    2001 Buick Regal LS - Almost Stock
  8. #8 Re: Oil filters
    GT Level Member 05SS45's Avatar
    Jan 2009
    westport maSS
    i have been running K&N, but im going to be going back to ac/delco. alot cheaper & from what i hear from my instructor's stock oil filters are the best.
    Going back to stock *GRANT built trans BLOWN w/17k*
  9. #9 Re: Oil filters
    TDCRacing
    Guest
    Wix. (Same as a napa)
    Some of you must not have seen the inside of some of these filters that your using. The only one I can speak for is the WIX and the FRAM. I will never put a fram on any of my cars. Ever. Because I have seen the inside of one and know how poorly designed they are.
    K&N seems to be a good filter. But I perfer WIX.
  10. #10 Re: Oil filters
    TDCRacing
    Guest
    BTW the I have also done a little research on the wal-mart brand (Tech something?) and it seems to be leaps and bounds better than the FRAM and is a little cheaper (For all of those using the FRAM filters)
  11. #11 Re: Oil filters
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    im currently using an ac delco, but i just bought 10 wix filters, so ill be using those for a while
    TDC, you can see for yourself how the supertech compares to the fram here:
    http://www.bobistheoilguy.com/forums...Number=1530978
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  12. #12 Re: Oil filters
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    Ran Acdelco since on all my gm's
    Few years ago a guy named Bobistheoilguy.com did a big research and test out the flow rate and build quality. Acdelco was at the top. In the end even K&N was just below the delco filter.
    Delco PF47 for ever LOL - And they are cheap
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  13. #13 Re: Oil filters
    Charles City, IA
    I might switch to ac delco. We carry them at work so I might be able to get them cheep.
  14. #14 Re: Oil filters
    Moore, Oklahoma
    An AC/Delco is a very good quailty filter, i've cut one up before. I may cut another one up this weekend since the black car is due for an oil change.....
    Shawn W. Larsen
  15. #15 Re: Oil filters
    Dec 2008
    Lawndale, CA
    I use the delco filter or the K&n.
  16. #16 Re: Oil filters
    Aug 2008
    Long Island, New York
    K&N
  17. #17 Re: Oil filters
    Barksdale AFB, LA
    Amsoil/K&N/ACDelco depending on the situation and what's readily available.
    I will never use Fram after seeing them fail a lot.
    2009 Subaru Impreza WRX STI
  18. #18 Re: Oil filters
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    fram, never had an issue with it. only issue is the 3 car shops around here only carry the filters for my car in fram sooo not much of a choice, i've tried looking for tech (walmart), ac delco, and k&n, They just dont carrey the model for my GP
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  19. #19 Re: Oil filters
    Houston, TX for now
    Here is TX K&N is cheeper than Mobile1 so I run it. It is funny how all the "studies" don't ever agree. 2 or 3 years ago there was a big study released on effectiveness and flow. Mobile 1 edged out Wix for #1 by a hair. But considering the price difference Wix was the best there was. I'll have to see if I can still find that post somewhere. I guess the one thing that I can say from personal experience is fram filters are almost all the same. Back in the day most of the filters were made in Clearfield, UT. My first job was there and the biggest difference is the cannister size. We only had to different papers and they weren't very different.
    2000 GRAND PRIX GTP COUPE WITH THE NORMAL LIST MODS TO MAKE IT LOUDER, FASTER AND OF COURSE SEXIER!! 267 WHP @ 9000 FT ABOVE SEA LEVEL
  20. #20 Re: Oil filters
    Aug 2008
    Fayetteville, NC
    yesterday I drove 35 minutes to another advanced auto store and found K&N at $13.50 and then I purchased 5 quarts of royal purple at like $7.50ea. WOW never again lol...i'm bout to go ride the bike so i'll change it later.
  1. oil filters dissected
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 07-14-2009, 10:20 AM
  2. Amsoil Nanofiber filters VS. ALL
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2008, 10:45 PM
  3. Over tightening oil and fuel filters
    By Andrew_99GTP in forum The Rant Forum
    Last Post: 04-15-2008, 01:34 AM
  4. Cone filters
    By bat119 in forum General Tech Discussion
    Last Post: 02-27-2008, 06:00 PM
