I just need some suggestions on what K&N I should buy when I'm just going to run it off of my TB. The current one I have is too long and impacts other objects under the hood (stupid me)I'm thinking a rather short and oval one.
what year and model car do you have?
I have a 98 GTP.......not sure if you know this already or if it helps you, but they make a GM part that relocates your radiator overflow to the passenger side by the strut tower so that you have room for more things over there........if you would like I could send you a link for that part. I hope this helps. It makes things less cluttered in this area. This unit is stock for all models 99 and newer.
Otherwise if you leave it by the TB, you will be sucking in a lot of hot air. Your decision though
http://www.pfyc.com/pc/GP3009/GP/gp3009.html this is where you can get it, it is a geniune gm part and comes with hose........or you can find one in a junkyard.
not sure why the link won't work but pfyc has it.........around 40 dollars if I remember correctly.
I haven't done this to my vehicle yet, but will be soon when installing the CAI......fwiw
congrats on getting the mod bug........I hope you like opening your wallet. Get used to it and have fun.............
you gonna do the powerlog at the same time as the downpipe?
Cone filter off the TB will only hurt you unless you are heavily modded. Relocate the coolant bottle and make a fenderwell.
