Thread: Filter off of TB: Choices...
Results 1 to 20 of 20
  1. #1 Re: Filter off of TB: Choices...
    Cone filter off the TB will only hurt you unless you are heavily modded. Relocate the coolant bottle and make a fenderwell.
  2. #2 Re: Filter off of TB: Choices...
    QFT. you can only pull off an open come with a substantial amount of mods. namely: an intercooler.
  3. #3 Re: Filter off of TB: Choices...
    SE Level Member Space Dynamics's Avatar
    Beltano Orbital Station
    Seriously? Even with all the problems the stock intake has it would still be better then running it right off of the Throttle Body?
  4. #4 Re: Filter off of TB: Choices...
    Wausau, WI
    Quote Originally Posted by Space Dynamics View Post
    the stock is still closer to the fender, not sucking quite as hot of air......neither are ideal.
  5. #5 Re: Filter off of TB: Choices...
    Yes. Seriously. But if you don't believe us put a filter on your TB and feel it die after 2500-3000 rpm's when it heats up.
  1. cam choices
    By popeyenate in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-29-2009, 08:17 PM
  2. Which oil filter?
    By Pontiacman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2009, 10:01 AM
  3. what filter is best?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-03-2009, 11:50 PM
  4. Anyone have an S&B filter?
    By Iron Indian in forum Off Topic Discussion
    Last Post: 04-12-2008, 07:18 AM
