Thread: spark plugs
Results 1 to 20 of 27
  1. #1 spark plugs
    in a house
    I have not had my car for long so decided to have a look at the plugs. The colour looks good but I see that their NGK TR55 GP. From what I've read its an iradium plug which is probably not the best for a supercharged car? They look like they are in really good shape but the reason I checked them because Im getting KR when not in boost? I notice that if Im cruising along at 60 mph on a road with hills I can get upwards to 8* KR when going up the hill and the engine is under load? I get very small amounts >1* under boost. I guess Im asking 2 things;
    Could the plugs be the reason for this KR?
    If I need to change plugs please tell me what a good plug for these cars preferably (champion) What heat range?
    Thanks
  2. #2 Re: spark plugs
    in a house
    8 views and no replys. Anyone?
  3. #3 Re: spark plugs
    No...it isn't the plugs...it sounds like false knock...do you have any exhaust mods? If you do they might be hitting the front sway bar...if so, filp it over...it is a common issue with larger exhaust systems.
  4. #4 Re: spark plugs
    TDCRacing
    Guest
    Well first off what do you have done to your car? It could be a lot of things. Give us a little more info.
  5. #5 Re: spark plugs
    in a house
    Quote Originally Posted by TDCRacing View Post
    Front plog,u-bend delete,zzp ported tb,3.3 pulley,1.9 rockers,overkill tune,u-drive pulleys. Everyone will say the pulley is too small but like I said I only get this at cruising speeds in 4th when the engine is under load. Maybe a fueling issue? I only run 93. Fuel filter was changed recently. I dunno but if it were under boost I would change pulleys butthe 8* KR has me stressed especially when its just cruising along. Dirty injectors?
  6. #6 Re: spark plugs
    TDCRacing
    Guest
    And I will say it also. The Pulley is your problem.
  7. #7 Re: spark plugs
    in a house
    Ok, but when its not boosting why would the pulley be the problem? I get less than 1* under full boost? Please explain, I have no problems changing the pulley if that is the problem
  8. #8 Re: spark plugs
    TDCRacing
    Guest
    Well it could be a lot of things but with the pulley being that small that is what the problem is.
    It could be Torque Management
    It could be the TCC not unlocking when it should
    It could be to much timing in the wrong parts of the Timing Table
    All of those things have to be changed inside of the PCM. I bet if you changed the pulley your KR would reduce in the area that you are seeing it at.
  9. #9 Re: spark plugs
    in a house
    Hmm, I appreciate your feedback but dont agree. If I was seeing this under boost than I would agree. I could pull the belt off and still get the same results so how could it be the pulley? This pic was done after an hour of driving and it was 86 and humid. If the pulley was to small, Im sure I wouldnt be getting .2* KR. Maybe Im just not understanding this KR thing.
  10. #10 Re: spark plugs
    Quote Originally Posted by silverstreak View Post
    If you ask for advice then disagree then why ask for it in the first place. We are all here to help and were not right next to you with a tuner or scanner so cut us some damned slack, ok?
    I still say go flip the sway bar. I say it is false knock.
  11. #11 Re: spark plugs
    ct
    " iradium plug which is probably not the best for a supercharged car?"
    I thought thats what we were supposed to be running in SC cars. The more I know, the less I know......
  12. #12 Re: spark plugs
    in a house
    [QUOTE=bluegtp91;207068]If you ask for advice then disagree then why ask for it in the first place. We are all here to help and were not right next to you with a tuner or scanner so cut us some damned slack, ok?
    Whaaat? Easy their tiger, since when does anyone have to agree with advice they are given? I dont think I came across as an a$$hole. I think I even said "I appreciate the feedback" Its called problem solving dude. Asking questions, giving info, feedback, discussion.
    Wow, your sensative, next time you see a thread created by myself, dont read it, Im asking for advice, not drama. Im sorry if that offends you but........
    Code:
    Their was no need for that.
  13. #13 Re: spark plugs
    in a house
    Well, put the 3.8 stock pulley back on, same thing. Any other idea's?
  14. #14 Re: spark plugs
    Jersey
    coppers are the best for these cars. I run autolite 103's but NGK coppers imo are better. I'll 2nd false knock. bluegtp and TDC are both respectable members here only trying to help you...they give you great advice and you say its wrong...
    16' wrx sti- stock
  15. #15 Re: spark plugs
    in a house
    Quote Originally Posted by 99prixgt View Post
    I dont doubt they are both very knowledgable. I never doubted the false knock either, highly possible. What I did doubt was that the pulley was to small and even though I doubted it I still went out and put the 3.8 back on and same thing. Then I get told to cut them some damn slack? LOL OK.
    Thanks for the advice on the plugs which was one of my original questions. I wasnt trying to prove anyone wrong here, again, its called problem solving and appears its not welcome here. Heres our advice, were right, f off. lol
  16. #16 Re: spark plugs
    It beyond welcome...you've just said in more than this thread about you getting all up about you having .2* of knock...ok, we get it, you pulley size it fine, Parker was giving his 2 cents worth. That is what the "cut us some damned slack" was about, not to bust your balls, which it seemed it did...so my biz. It just seems me and Parker give advice and you say "I don't agree"...internet wording always sucks because you can never understand the emphasis that you put on the words...maybe I took it wrong idk...it is definitely one of those days today.
    I still say its false, or burst knock...something is coming in contact with something (solid to solid) and making that knock sensor freak out and cut your timing...
  17. #17 Re: spark plugs
    TDCRacing
    Guest
    well after listening to you about doing what you did with the pulley and belt i'd have to agree that it's not the pulley. I'll have to take my statement back about the pulley but it still could be something in the PCM.
    I bet the EGR needs to be disabled. A lot of people have problems with part throttle KR becuase of this.
    It's worth a try. Try unplugging it. Or better yet try taking it off and blocking the ports off.
  18. #18 Re: spark plugs
    in a house
    Hey, no need to take any statement back, I started to have my doubts too...obviously thats why I tried it. Telling you that was not the problem was not meant to be offensive but nessesary when problem solving. I tried searching the forum for disconnecting the egr and found nothing. If you have a chance can you explain or maybe post a link? Thanks again.
  19. #19 Re: spark plugs
    TDCRacing
    Guest
    Oh it's cool,
    The problem with the EGR was a lot of people were having PT Knock. And all of their problems went away when they disconnected the EGR compleatly. You can do this by taking the EGR off and cutting the two mounting flanges off of the metal tubing. Then you take a nickel and a penny and put the penny on the header side and the nickel on the LIM side and rebolt the mounting flanges over the penny and nickel..
    If that does not wor it would seem like it would be an issue in the PCM or false knock.
    Let me know if I need to explain any more.
  20. #20 Re: spark plugs
    in a house
    Oh it's cool,
    Ok, I will give it a shot, will this screw with emissions? Nice 6 cent fix. lol
  1. spark plugs
    By Nos shottss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-18-2009, 12:32 PM
  2. spark plugs
    By Nos shottss in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-12-2009, 09:34 PM
  3. What spark plugs?
    By Dwhip in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-25-2009, 08:21 PM
  4. spark plugs
    By NEONNIGHT34609 in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-07-2008, 09:43 PM
  5. Spark Plugs
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-27-2008, 10:45 PM
