Thread: DIC Light up
Results 1 to 9 of 9
  1. #1 Re: DIC Light up
    Wausau, WI
    they come stock backlit with bulbs...........you can switch to LED's but if you do, then I don't believe it will dim with your headlights at all..............from what I remember anyway don't count on this as 100% fact.
  2. #2 Re: DIC Light up
    germantown
    just checked the five lights and only one was bad on the display, so i replaced it with a new bulb but display does not illuminate at all. only the low trac and trac control lights illuminate. Is the left hand circuit done for and how could i fix it or do i need a new dic? thanks for the help
  1. ABS Light + Check Tire Press. Light Problems
    By element55 in forum Brakes/Suspension/Chassis
    Last Post: 01-30-2009, 02:34 PM
  2. ABS/TCS Light
    By TCO in forum General Tech Discussion
    Last Post: 01-18-2009, 02:41 AM
  3. SES Light
    By sws922 in forum General Tech Discussion
    Last Post: 11-01-2008, 01:30 PM
  4. ZZP dp & SES light
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2008, 01:47 PM
  5. Head Light/Tail Light Covers
    By datApocalypse in forum Visual/Body Modifications
    Last Post: 01-30-2008, 11:38 PM
